1984 W150 4x4 front end assembly question (snap ring) #1376404
01/26/13 04:29 PM
01/26/13 04:29 PM
northeast ohio
hulmule Online content OP
hulmule  Online Content OP
northeast ohio
Bought this 1984 4x4 1/2 ton to fix up. Came with a box of parts ,cause they started to tear apart the front hubs. Someone at one time, put on M@M lock outs on it. Well everything is in pieces,found one snap that is bent up and missing one for the other side.Went to all auto parts stores and tractor supply , found a couple that are close but not really correct.The original snap ring is thick and solid and the replacement ones are thinner and cheezey.Worried about it not hold the assembly together correctly. Besides trying to find something in a junk yard that old and not damaged where can i get two?? would really like to get this front end back together. Any dodge web site that shows this break down and call out the size and thickness of this snap ring?? Thanks !
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 1984 W150 4x4 front end assembly question (snap ring) [Re: hulmule] #1376405
01/26/13 07:11 PM
01/26/13 07:11 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Buy New
Re: 1984 W150 4x4 front end assembly question (snap ring) [Re: 76dodgeboy] #1376406
01/26/13 10:38 PM
01/26/13 10:38 PM
northeast ohio
northeast ohio
love to buy new !! but where??
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 1984 W150 4x4 front end assembly question (snap ring) [Re: hulmule] #1376407
01/26/13 10:53 PM
01/26/13 10:53 PM
MI
68shifter Offline
68shifter  Offline
MI
I think he's referring to new lockouts. You can get warn and mile marker for less than $100. Otherwise try a true nut/bolt supplier. They typically stock more odd size stuff. Local 4WD and driveline shops should be able to help too.
Re: 1984 W150 4x4 front end assembly question (snap ring) [Re: 68shifter] #1376408
01/26/13 11:22 PM
01/26/13 11:22 PM
northeast ohio
northeast ohio
wow $100 for 2 snap rings!! maybe i can call M&M and buy 2 snap rings. I think it was the stock hubs that used them
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 1984 W150 4x4 front end assembly question (snap ring) [Re: hulmule] #1376409
01/26/13 11:25 PM
01/26/13 11:25 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
No $100 for the Lockouts
Re: 1984 W150 4x4 front end assembly question (snap ring) [Re: 76dodgeboy] #1376410
01/26/13 11:40 PM
01/26/13 11:40 PM
northeast ohio
northeast ohio
So i have a extra set of lock out laying around just missing the snap rings LOL
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 1984 W150 4x4 front end assembly question (snap ring) [Re: hulmule] #1376411
01/27/13 12:19 AM
01/27/13 12:19 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Some aftermarket hubs do not use a snap ring on the axle shaft. Be sure so find the install instructions for the hubs you intend to use.
Re: 1984 W150 4x4 front end assembly question (snap ring) [Re: NITROUSN] #1376412
01/27/13 03:14 AM
01/27/13 03:14 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Here's a thought call the company that makes your current Lockouts and get the parts you need
Re: 1984 W150 4x4 front end assembly question (snap ring) [Re: 76dodgeboy] #1376413
01/27/13 04:42 PM
01/27/13 04:42 PM
northeast ohio
northeast ohio
Been on line looking at the company. looking for a parts list but they dont seem to show any.got a email into them already.- Trust me im on it! trying to cover all my bases as i move forward.i like coming to moparts and ask cause i hate to wait for answers from customer service.
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 1984 W150 4x4 front end assembly question (snap ring) [Re: 68shifter] #1376414
01/27/13 04:53 PM
01/27/13 04:53 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
4 Wheel Drive Hardware, Columbiana,Ohio
330-482-4733
1981 Dodge D150 360 auto
