E-Body Shifter Boot #1376332
01/26/13 12:53 PM
01/26/13 12:53 PM
MD
floyd Offline OP
floyd  Offline OP
MD
What is the correct part number for a 70-71 E-body shifter boot (with console if that matters)?
I have two with the same part number (3467770). The tall one is very hard and not pliable, the shifter frequently pops out of third gear.
The shorter one is unused NOS and is much more flexible. Do they stretch out and get harder with age or is that a variation in vendors?
A lot of the repros I see appear to be tall. Any recommendations for a good reproduction?
Re: E-Body Shifter Boot [Re: floyd] #1376333
01/26/13 04:33 PM
01/26/13 04:33 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
it's not so much that it stretches out as to the width of the shifter going through the slot..a narrow shifter will hold the boot higher as a wider boot will slide it down further..
Re: E-Body Shifter Boot [Re: AARCONV] #1376334
01/26/13 06:22 PM
01/26/13 06:22 PM
california
Mr D21 Offline
Mr D21  Offline
california
The original rubber boots are much softer then any of the reproductions. And the repops rip easily.
If I remember correctly, for some reason the 3&4 speed (non-pistol grip) boots share the same part number as the pistol grip boots.
Its strange but true,,,,
Re: E-Body Shifter Boot [Re: Mr D21] #1376335
01/26/13 09:25 PM
01/26/13 09:25 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
The correct three speed NOS shifter boot is 2996 405, I have five NOS ones stamped with that part number.
Re: E-Body Shifter Boot [Re: m46rat] #1376336
01/26/13 10:37 PM
01/26/13 10:37 PM
california
Mr D21 Offline
Mr D21  Offline
california
My 70 untouched all original 4spd had the 405 in it - Can anyone confirm the assy line number for the pistol grip boot - the books says 2950201. I have never seen one ??
Re: E-Body Shifter Boot [Re: Mr D21] #1376337
01/27/13 12:42 AM
01/27/13 12:42 AM
m46rat Offline
m46rat  Offline
I also have two NOS three speed boots stamped 3467 770.
Re: E-Body Shifter Boot [Re: m46rat] #1376338
01/27/13 12:20 PM
01/27/13 12:20 PM
california
Mr D21 Offline
Mr D21  Offline
california
and #3467 770 is the same part number as the pistol grip boots...
Re: E-Body Shifter Boot [Re: Mr D21] #1376339
01/28/13 10:07 AM
01/28/13 10:07 AM
MD
floyd Offline OP
floyd  Offline OP
MD
Thanks for all the replies! I still don't get it though. The 3-spd boots had the round hole right?
Re: E-Body Shifter Boot [Re: floyd] #1376340
01/28/13 08:00 PM
01/28/13 08:00 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
The taller boot is a later production and the rubber is very thick. They were still available a few years ago, might still be however they will pull the car out of gear like was stated.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: E-Body Shifter Boot [Re: Dan Brewer] #1376341
01/28/13 08:48 PM
01/28/13 08:48 PM
MD
floyd Offline OP
floyd  Offline OP
MD
Re: E-Body Shifter Boot [Re: Mr D21] #1376342
01/29/13 09:07 PM
01/29/13 09:07 PM
m46rat Offline
m46rat  Offline
Just checked some of my parts books:
70 lists the 2950 201 number for V and L A Bodies(oblong)
70-71 lists the 2950 201 number for E and B Bodies(oblong)
70 lists the 2996 405 number for 3 and 4 speed E Bodies(square)
70-71 lists the 2996 405 number for 3 and 4 speed E Bodies(square)
72 lists the 3467 770 number for 3 speed E and B bodies
72 list the 3467 766 number for 4 speed E and B bodies
I think the 2950 201 number may be an error in the 70-71 book, it should be an A Body four speed shifter, A Body guys will have to chime in and let us know.
70 and 70-71 books list the 2996 405 number for both 3 and 4 speed cars but list the boot as square with no mention of oblong(which I assume means round?)
The 72 book is the first one that mentions the 3467 770 number but only in reference to a 3 speed. Has anyone seen a boot with the 3467 766 number stamped into the base?
Looks like the 2996 405 and 3467 770 are somehow correct for both the 3 speed and four speed cars. From our posts it seems that both do indeed exist with both sets of part numbers and with both the oblong and square tops on them.
Comments please!
Re: E-Body Shifter Boot [Re: m46rat] #1376343
01/30/13 02:01 AM
01/30/13 02:01 AM
Ontario, Canada
mccannix Online content
mccannix  Online Content
Ontario, Canada
Correct on the taller boot with the taller neck being the later production.
Here's what you got from your dealer in 1972 for $3.84...NOS boot with 3467770 on the side and then the vendor code...mine is the same style as the short one pictured.
Bruce is the vendor code 53495 the same for both.
Re: E-Body Shifter Boot [Re: mccannix] #1376344
02/16/13 11:28 AM
02/16/13 11:28 AM
MD
floyd Offline OP
floyd  Offline OP
MD
I just saw your question Terry - Yes, same vendor code for both parts
Re: E-Body Shifter Boot [Re: floyd] #1376345
02/18/13 12:24 AM
02/18/13 12:24 AM
MN
astrobuf Offline
astrobuf  Offline
MN
OK, so I have a repop boot that is the tall type and indeed does cause my shifter to pop out of gear. Who makes the shorter boot?
Astrobuf
So, are you really a Rocket Scientist?
Re: E-Body Shifter Boot [Re: astrobuf] #1376346
02/18/13 11:12 AM
02/18/13 11:12 AM
MD
floyd Offline OP
floyd  Offline OP
MD
The one Brewer's shows appears to be shorter but I haven't seen it in person yet.
http://www.brewersperformance.com/proddetail.asp?prod=SB770
Re: E-Body Shifter Boot [Re: floyd] #1376347
02/18/13 12:53 PM
02/18/13 12:53 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
NOS boot from the 1970s...
Re: E-Body Shifter Boot [Re: xs29j8] #1376348
02/18/13 12:55 PM
02/18/13 12:55 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Re: E-Body Shifter Boot [Re: xs29j8] #1376349
02/18/13 01:39 PM
02/18/13 01:39 PM
california
Mr D21 Offline
Mr D21  Offline
california
I have about 20+ NOS boots - if anyone needs one, just send me an email... $150 includes shipping in the USA....
Re: E-Body Shifter Boot [Re: Mr D21] #1376350
02/20/13 04:56 PM
02/20/13 04:56 PM
new york
P
paris401 Offline
paris401  Offline
P
new york
whats the part number?
Re: E-Body Shifter Boot [Re: paris401] #1376351
02/20/13 09:04 PM
02/20/13 09:04 PM
california
Mr D21 Offline
Mr D21  Offline
california
theres only one 4spd boot number #3467 770
As pointed out, there's 2 flavors - short & tall, I believe the difference is based on manufacturing date as the rubber is slightly different.
The tall ones seem to be the most prevalant - early NOS versions are shorter and softer...
