Re: TRUE HOOD SCOOP TESTS...........................
[Re: 493_DART]
#1375790
01/27/13 12:22 AM
01/27/13 12:22 AM
Posts: 1,030 ohio
67mprfan
ohio
I'll be watching this for updates as i also need a different hood because my carb sits at the top of my scoop
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#1375791
01/27/13 01:32 AM
01/27/13 01:32 AM
Thumperdart
State of confusion
Ya that looks tight under there for sure and although it looks like I might have just a bit more clearance than you I still want a taller filter than the 14x3 I run now.
[Re: Thumperdart]
#1375797
01/29/13 04:31 AM
01/29/13 04:31 AM
Posts: 4,648 aotearoa
rebel
aotearoa
Ya I remember about Rebel`s deal and really would like about a 6" 6-pac scoop but havn`t really looked yet........
dude, i'm a total convert over the cowl deal for more mph & lower e.t but i've also found another improvement with a cowl since then. you might not race in the rain but i sure do tow home in the stuff. a cowl keeps my air filter looking clean as new since the road grime isn't being mixed with the rain going thru a 6 pak. keeps the motor dryer too.
[Re: Thumperdart]
#1375802
01/30/13 03:11 PM
01/30/13 03:11 PM
Posts: 554 Kentucky
clovis
Kentucky
After reading until I was numb, I settled in on the aero scoop. It seems the keys factors as has already been spoken is getting it in clean air and getting it sealed. I'll post a couple of pictures that shows a little of what I did.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: clovis]
#1375804
01/30/13 03:14 PM
01/30/13 03:14 PM
Posts: 554 Kentucky
clovis
Kentucky
The hard part was getting something I could lift up the hood with and when closed would seal up. It is amazing what you can do with a 99 cent pie plate.
[Re: clovis]
#1375805
01/30/13 03:14 PM
01/30/13 03:14 PM
Posts: 554 Kentucky
clovis
Kentucky
Last one When the hood is close the air bell rides down inside the pie plate to form the seal. I did put some foam around the pie plate to ensure it was making a good seal. I beleive the air bell helps also as it makes for a good transition into the carb.
[Re: Thumperdart]
#1375807
01/30/13 05:38 PM
01/30/13 05:38 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
I have a scoop like that if you want Dom, pm me.
Founder and CEO of the Central Valley Mopar Drag Pack
