Page 4 of 4 1 2 3 4
Re: rocker offset?Victor RB heads. [Re: Clanton] #1375468
02/05/13 06:48 PM
02/05/13 06:48 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I see comp cams has cut to length pr 8.5" to 9.800" w/press in cup so that is 1 option.
Its been awhile since I checked but isn't standard size something like 9.750 cup ball for a 440. If so a good used set should be cheap and real easy to find. If that's close let me know. I have several sets.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: rocker offset?Victor RB heads. [Re: pittsburghracer] #1375469
02/05/13 08:43 PM
02/05/13 08:43 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The lifter you use makes a difference,I am using a comp roller 829 with a seat height of 1.79 and with that I measured the with the checking pr and got the 9.422 measurement and measuring my old pr side by side the new is .500 taller +/-.The simple answer is no that is not the correct length.
Re: rocker offset?Victor RB heads. [Re: Clanton] #1375470
04/01/13 01:08 PM
04/01/13 01:08 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Now that the weather is getting better I can think about putting on the heads and get away from making headers for now.
Page 4 of 4 1 2 3 4
