Re: rocker offset?Victor RB heads.
[Re: Jeremiah]
#1375430
01/25/13 10:50 PM
01/25/13 10:50 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Thanks!I just cut a pushrod to make it adjuastable to check the length I need and have full scale to check the clearence.
[Re: prochargedhemi]
#1375434
01/25/13 11:07 PM
01/25/13 11:07 PM
Clanton
northern,Ohio,USA
I "planned" on using a solid flat tappet but it looks like that idea may be changing as we speak
Maybe we can get some more info in the next couple days to help decide.
[Re: Clanton]
#1375435
01/25/13 11:16 PM
01/25/13 11:16 PM
Clanton
northern,Ohio,USA
I don't know what good this info is but the push rod clearance on the port is 7* ground into the port. ps,I double checked my rocker offset with the 7* on the pushrod and I would need .8025 total offset to be o/c on the v-stem.with my adjustable pr I will check with things mocked up. ![](/ubbthreads/images/graemlins/shruggy.gif) edit:A 9.5" pushrod offsets .875 at 7*
[Re: Deepockets]
#1375437
01/26/13 11:40 AM
01/26/13 11:40 AM
Posts: 4,213 New York
polyspheric
New York
get crazy with the offset on the rockers, it eill increase the side load on the lifters
Backward - the offset should make the pushrod vertical to the tappet axis with no side-thrust.
Boffin Emeritus
[Re: Clanton]
#1375440
01/26/13 05:01 PM
01/26/13 05:01 PM
Clanton
northern,Ohio,USA
the angle of the pushrod is only 3* installed,any grinding will be at the top of the port and there is plenty of meat there.If you have any question I can remeasure.
