Caltrac Mono Leafs & Sliders
#1374397
01/22/13 09:26 PM
01/22/13 09:26 PM
Posts: 89 Woodbury, CT.
mcduff
Woodbury, CT.
Thinking about using some afco rear spring sliders with my caltrac mono leaf setup along with some new DA Shocks..Anybody out there have any results inc, gains/losses in 60' times they would like to share after using sliders? Thanks
Brett Miller 447 W9
Re: Caltrac Mono Leafs & Sliders
[Re: mcduff]
#1374398
01/22/13 09:35 PM
01/22/13 09:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I assume your talking the slider at the rear instead of shackles .... I like them and have put them on cars with springs... I cant say how they would change anything on a caltrac set up... all that work is done in front of the axle... the portion behind the axle is the ride rate.... but they slide nice and smooth but I would suggest to spray them once in a while to keep them clean ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1374399
01/22/13 10:09 PM
01/22/13 10:09 PM
mcduff
Woodbury, CT.
Yes Mike I am talking about the rear of the spring. Trying to understand if there is any benefit in reducing/controlling the rise in the chassis created by the arc in the shackle swinging down on the hit. I understand Calvert is now recommending sliders with mono leafs. Thanks ![](/ubbthreads/images/graemlins/thumbs.gif)
Brett Miller 447 W9
[Re: mcduff]
#1374400
01/22/13 10:22 PM
01/22/13 10:22 PM
MR_P_BODY
The shackle in itself doesnt do anything... per say BUT the rubber does bind up then snap free but its usually such a small amount it doesnt upset the chassis but the sliders are smoother... will you see a gain... I really doubt it but they do lower the back end and THAT might help in transfer ![](/ubbthreads/images/graemlins/wave.gif)
[Re: WHITEDART]
#1374402
01/22/13 10:51 PM
01/22/13 10:51 PM
MR_P_BODY
yes I have this setup on my 68dart and has worked very well..cal tracks mono 1" drop with a slider .. I welded my sliders to the car don't make this mistake bolt it best 60ft 1.32 with 29 10.5 micky
I weld them on.... no issues what so ever ![](/ubbthreads/images/graemlins/wave.gif)
[Re: WHITEDART]
#1374405
01/22/13 11:19 PM
01/22/13 11:19 PM
MR_P_BODY
mr p : dose this sound like a good idea
I dont do it that way... if you want some added weight raise the opposite T-bar... since they are wider than the frame I weld a piece of steel on the frame so they dont hang over and weld them directly to the frame ![](/ubbthreads/images/graemlins/wave.gif)
[Re: WHITEDART]
#1374409
01/23/13 11:13 PM
01/23/13 11:13 PM
MR_P_BODY
I would say any time you can gain adjustability it is a good thing. bolting your slider would not be much more work and give you some options. then you would have 4 corner adjust.
If you want... to me its just another thing that can go wrong..... JMO... your the only guy I heard of that bolts them on... but if it works for you keep doing it ![](/ubbthreads/images/graemlins/wave.gif)
[Re: mshred]
#1374413
01/24/13 12:17 AM
01/24/13 12:17 AM
MR_P_BODY
I've read of more guys bolting them on then guys welding them on.
Also, what are you guys using to lube them? Just your run of the mill wheel grease, oil, or???
Like I said "I" havent seen anyone bolt them on... maybe if someone doesnt have a welder they would bolt them on.... the ones I have put on are welded... I use a spray white grease ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1374414
01/24/13 12:20 AM
01/24/13 12:20 AM
Posts: 3,429 Toronto
mshred
Toronto
Just stating what I have read and heard is all Mine are welded on also...it was suggested to me that I bolt them on for the same reasons that whitedart mentioned, but I felt more comfortable welding them.
Thanks for the info on the grease also! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: mshred]
#1374416
01/24/13 12:35 AM
01/24/13 12:35 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I would say more important than trying to lube the sealed bearings.. is to keep it clean the rubber and rocks will build up .. one of the things that I like the most about this set up is less side to side movement..john calvert will tell you for a trans brake set up run a bunch of shock so you wont see much movement at the slider. my set up will move less than 1/2 inch on a pass
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
