Ring & Pinion WOW!
#1374357
01/22/13 08:25 PM
01/22/13 08:25 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
Has anybody seen this before, brand new ring & pinion broke in per instructions, 4th pass down at the track at the big end with a small block! Really!
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
Re: Ring & Pinion WOW!
[Re: 65signet]
#1374360
01/22/13 09:42 PM
01/22/13 09:42 PM
Posts: 1,532 off the grid
340B5
off the grid
Grain pattern looks loose in that pic. There should be a tighter grain pattern around the outer edge.
Yeah, it's got a smallblock.
[Re: sam64]
#1374361
01/22/13 09:43 PM
01/22/13 09:43 PM
65signet
El Dorado Ca
Is that because the metal is to hard? and i don't see why the driveline would let go when it has the least amount of force on it i was at a 1000 ft, its a street car and only runs low 11's
[Re: 65signet]
#1374362
01/22/13 09:45 PM
01/22/13 09:45 PM
Posts: 1,853 South Bend
John Brown
South Bend
I'd think it's time to have the remains checked for hardness.
[Re: 65signet]
#1374364
01/22/13 09:57 PM
01/22/13 09:57 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Strang that it broke at the top end of the track.. but that grain looks weird... I dont think its over hardened... if it was there would be sharp edges on parts of the break... but its not soft... you dont see any twisting lines... weird
[Re: 65signet]
#1374369
01/22/13 11:23 PM
01/22/13 11:23 PM
dartman366
Mt. Vernon, Ohio
could be a thermal fracture from heat treat or a lamination from the parent material.
[Re: dennismopar73]
#1374373
01/23/13 05:26 AM
01/23/13 05:26 AM
Posts: 2,141 junction city oregon
viperblue72
All 4 u joint bolts have been hitting something? ,The issue maybe the axle wrap up and putting drive shaft in a bind would be my best guess
That could be from when it hit the ground spinning at 100+ mph?
[Re: viperblue72]
#1374375
01/23/13 09:45 AM
01/23/13 09:45 AM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
I'd say no, the flange behind it doesn't look worn down.
[Re: viperblue72]
#1374376
01/23/13 10:45 AM
01/23/13 10:45 AM
Posts: 167 maryland
74yellowduster
maryland
Is that break right where the splines start? Maybe not enough radius on the edges where the splines begin? That would make it break really easily right there.
what if the pinion nut was not torqued to spec? could that cause this?
[Re: 65signet]
#1374377
01/23/13 11:26 AM
01/23/13 11:26 AM
Posts: 11,688 W. Kentucky
justinp61
W. Kentucky
No vibration very smooth going down the track
If the u-joint was hitting something I don't think the OP would've posted this.
[Re: 65signet]
#1374385
01/24/13 09:07 AM
01/24/13 09:07 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
We have seen this quite a few times and have done it once myself.Usually it's overtorque that caused the problem.I assumed my airwrench would only torque to 150# wrong.I was left holding the yoke in my hand.Many assume the torque setting for a pinion nut is 240+# or as tight as you can get it with a 2 foot cheater pipe.There are varied setting depending on the pinion stem diameter and if it's straight or tapered.These specs can range from 125#ft to 250#ft.Always check with the manufacture for the correct setting.My thoughts are use a new lock nut,locktight and tighten as needed,you can even center punch the nut in several places to insure it doesn't back off.
Pinion nut was tighten to allow for the correct preload on the pinion with new bearings it was set to 20 inch pounds of rotation drag..
The pinion nut does not set preload.The crush washer if used or if its a straight pinion shims are used to set preload.
