Re: 273 hi-po has problems, please help....
[Re: dogdays]
#1374260
01/26/13 08:59 PM
01/26/13 08:59 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
The rocker ratio is the same, nominally 1.5. Have you checked and double-checked the firing order? Do it first, then: If you have an inductive timing light, idle the engine and put the inductive clamp on each plug wire. An even series of flashes means that plug is firing. Skipping flashes or no flashes means that plug isn't. R.
Just to clarify, skipping flashes or no flashes means a bad plug wire .
[Re: rowin4]
#1374261
01/28/13 11:40 AM
01/28/13 11:40 AM
Posts: 209 Arkansas
beatupcuda
Arkansas
thanks too all, and it appears stock length rod is 100 thousands longer than the ones in my engine.OK, gang, thanks for all the advise, help, info, etc... After doing & checking all that you have provided, I removed the valve covers to re-look at pushrods. They were new in appearence, and after checking more saw one loose. So I looked closer and realized one was "broke" the "Y" ball/cup top 3/8" of one rod had complete come seperated from the shaft and had mushroomed the shaft top approx at least 1/32" or more. So Now I will look for one pushrod for hyd ilfter but ball end rocker, for a short time until I buy a complete set from ? any suggestions here ? Summitt ? thanks
68 Hemi 4 speed Cuda,,,,building ?
[Re: beatupcuda]
#1374262
01/28/13 10:34 PM
01/28/13 10:34 PM
Posts: 660 San Diego
formula S
San Diego
Thats where I shop
[Re: formula S]
#1374263
01/29/13 04:07 AM
01/29/13 04:07 AM
Posts: 4,253 State of Fascism
52savoy
State of Fascism
Make sure you adjust the rockers with the lifters on the cam's base circle..low side.
