Re: Ridge Reamers
[Re: Commando1]
#1374217
01/24/13 02:12 PM
01/24/13 02:12 PM
Posts: 6,100 Valencia, España
NachoRT74
Valencia, España
I, ummm... appreciate the responses, guys. Thanks.
I'm talking about the reamer posted by Challenger1, which has a rubber shoe on bottom of the cutter what sets it to be angled like this / ... MAYBE ANOTHER KIND OF REAMER, able to make the cut totally vertical won't get you in troubles, and will need just to hone after the cut.
IMHO my mistake was on buy and use THAT reamer, at least without take care of the shoe. Maybe if I was removed the shoe, story was to be diff.
Re: Ridge Reamers
[Re: NachoRT74]
#1374218
01/24/13 03:18 PM
01/24/13 03:18 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
If I am looking at it right that piece at the bottom has to be like that to make the part expand out to the size of the bore .
This is why only a trained professional should be using one ... ![](/ubbthreads/images/graemlins/laugh2.gif)
Re: Ridge Reamers
[Re: JohnRR]
#1374219
01/24/13 03:25 PM
01/24/13 03:25 PM
NachoRT74
Valencia, España
TOTALLY TRUE! LOL
Re: Ridge Reamers
[Re: NachoRT74]
#1374220
01/24/13 03:50 PM
01/24/13 03:50 PM
Posts: 2,540 God's Country Maryland
GODSCOUNTRY340
Here's a pic of the one I've used since 1977. I actually bought it from JC Whitney, mail order. It's a KH 209 model.
Re: Ridge Reamers
[Re: 360view]
#1374223
01/26/13 12:13 AM
01/26/13 12:13 AM
Posts: 10,777 North Dakota
6PakBee
North Dakota
I'd be scared to try to remove a ridge with a rotary stone/bit/abrasive wheel, whatever. To maintain the tolerance you need for eight bores? Without botching one up? I'd go back to the reamer. The mistake I see people make with a ridge reamer is they turn it with a ratchet or a breaker bar. This imposes a side load on the tool and just makes it harder to maintain alignment with the bore. I get above the block (use a small step stool) and use a T-handle for the reamer so everything stays aligned. Just my ![](/ubbthreads/images/graemlins/Twocents.gif)
Re: Ridge Reamers
[Re: 360view]
#1374224
01/26/13 01:13 AM
01/26/13 01:13 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Step by step, how would be the best way to use a rotary tool to remove a ridge, and what would be the ideal flap or grinding wheel to use in the tool?
Should one try to totally remove the ridge, or just remove emough material to allow the piston rings to compress and pass over a reduced ridge?
Should one strive to keep the centerline of the rotary tool parallel to the line of the bore, or should the rotary tool be held at an angle to grind the original ridge into a shallow ramp shape?
Since saving the block from damage that forces an overbore is much desired, At what level of material removal should one stop for safety's sake?
Perhaps a shim of a few thousandths thickness could be held just below the ridge to keep the rotary tool wheel from accidently cutting too deep or too far down?
Your joking right ? The ridge reamer tool is the only way to do it, other than taking the block to the machine shop. The questions you have asked and if your block needs work done to it you had better have someone else do it. JMO ![](/ubbthreads/images/graemlins/Twocents.gif)
Re: Ridge Reamers
[Re: GODSCOUNTRY340]
#1374225
01/31/13 07:42 AM
01/31/13 07:42 AM
Posts: 4,163 Canada -- Posts: 4034 -Registe...
5thAve
That's the kind I'm familiar with. If you screwed up an engine with a ridge reamer either it already had issues or you didn't do it right. Either way it's not the tools fault.
