Page 2 of 3 1 2 3
Re: block porn it's here [Re: mshred] #1372980
01/21/13 10:27 PM
01/21/13 10:27 PM
Ambridge, Pa.
rickraw Online content OP
rickraw  Online Content OP
Ambridge, Pa.
yes sir, iron. it's about 15-20# heavier than an r3 block. whitedart, it has a 360 rear cap. kent is sending me a spacer for my charlies pan which has a 340 arch.
Re: block porn it's here [Re: rickraw] #1372981
01/22/13 11:10 PM
01/22/13 11:10 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
man I would love to see a pic of that spacer and how much it cost
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: block porn it's here [Re: WHITEDART] #1372982
01/22/13 11:16 PM
01/22/13 11:16 PM
Ambridge, Pa.
Ambridge, Pa.
i'll let ya know when ever i hear from kent. i will post a pic when i get it.
Re: block porn it's here [Re: rickraw] #1372983
01/22/13 11:21 PM
01/22/13 11:21 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
thanks I have been on kents call list before .. might be some time . but new casting looks nice I have the same one..
Re: block porn it's here [Re: WHITEDART] #1372984
01/22/13 11:32 PM
01/22/13 11:32 PM
Ambridge, Pa.
Ambridge, Pa.
did u have to drill any holes in the deck for water passages?
Re: block porn it's here [Re: rickraw] #1372985
01/22/13 11:58 PM
01/22/13 11:58 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Nice looking block Rick
Does it take a 340 or 360 rear seal?
Re: block porn it's here [Re: rickraw] #1372986
01/23/13 12:11 AM
01/23/13 12:11 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
what I can tell you is my old xr1 did not need any holes drilled.the new block is at the shop hopefully I can pick it up and take a look what holes are we talking about.
Re: block porn it's here [Re: WHITEDART] #1372987
01/23/13 05:19 PM
01/23/13 05:19 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
thats awesome. if you wanted, could that block be modified for oiling through the heads to use LA heads? amazingly nice block, but i do like LA heads and shaft mounted rockers.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: block porn it's here [Re: roadhazard] #1372988
01/23/13 08:42 PM
01/23/13 08:42 PM
Ambridge, Pa.
Ambridge, Pa.
Hey Greg, it's is 360 main cap. takes a special seal. never saw one like this. made by signal seals & fastners.
Re: block porn it's here [Re: rickraw] #1372989
01/23/13 08:44 PM
01/23/13 08:44 PM
Ambridge, Pa.
Ambridge, Pa.
another
Re: block porn it's here [Re: mopardude318] #1372990
01/23/13 10:44 PM
01/23/13 10:44 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
rocker oiling.... it would be a long way to drill.. maybe buy a very good shop ..but out side oil lines would work fine
Re: block porn it's here [Re: WHITEDART] #1372991
01/24/13 01:44 AM
01/24/13 01:44 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I see there are no steam holes in the deck, none needed?
Re: block porn it's here [Re: rowin4] #1372992
01/24/13 05:36 PM
01/24/13 05:36 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Sure is a lot of core shift of misplaced lugs for the lifter side extra head studs. The outside edge lines up great. The inside if pretty far off.
That rear seal is the rear main and is way superior to the stock style. The 360 rear pan seal is better to. smaller lighter cap.
Re: block porn it's here [Re: Leon441] #1372993
01/24/13 06:23 PM
01/24/13 06:23 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
I heard the cam tunnels were a problem too.I was just going to buy one for my new build until i heard there was still lots of problems that haven't been corrected.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: block porn it's here [Re: bdaz smblk] #1372994
01/24/13 06:53 PM
01/24/13 06:53 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I had several of those spacers to put 340 pans on 360 caps. Nothing specail. It is cast aluminum and you silicone it into the groove in the cap where the seal usually would go. Very easy to make with 3/8 aluminum plate.
Leon
Re: block porn it's here [Re: Leon441] #1372995
01/24/13 06:57 PM
01/24/13 06:57 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
That is cast to accomodate p7 studs. It's not shifted when drilled for them..(so I have been told)
Re: block porn it's here [Re: Hot 340] #1372996
01/24/13 09:10 PM
01/24/13 09:10 PM
Ambridge, Pa.
Ambridge, Pa.
that is correct. kent told me u can use, edy's, brodix & mopar heads. i had to drill some water passages in the deck for my w9's. kent told me hasn't heard of anyone trying w9's on his block i'll try to post pics of what i had to drill tomorrow.
Re: block porn it's here [Re: rickraw] #1372997
01/25/13 07:03 AM
01/25/13 07:03 AM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
all s/b guts need to thank kent ritter because without him we woud only have ma mopar, & that means NOTHING no parts, kents realy trying to built a quilty parts for us at a reasimble price,thanks kent
Re: block porn it's here [Re: Hot 340] #1372998
01/25/13 01:16 PM
01/25/13 01:16 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
That could be true but, I thought the Xr1 and XR2 where different castings. They may be the same casting and just machined differently depending on what heads you plan to run. That would make sense.
Re: block porn it's here [Re: Leon441] #1372999
01/27/13 01:12 PM
01/27/13 01:12 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
im not 100% on this. but xr2 has more cam bearings with a staggered lifer like 47 intake 59 ex .
Page 2 of 3 1 2 3
