Re: Rollbars/cages livable on the street?
[Re: dustergirl340]
#1371181
01/17/13 07:07 PM
01/17/13 07:07 PM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
Roll Bar: All cars running 11.49 or quicker must be equipped with a roll bar conforming to NHRA general regulations.
Roll Cage: All cars running 10.99 or quicker must be equipped with a roll cage conforming to NHRA general regulations*
*By NHRA rules, a roll cage is not required in a full bodied car until 9.99 or 135MPH. A roll cage is required between 10.99 and 10.00 only at speeds of 135 or higher.
Always lots of debate on this subject but for me a roll bar or cage equals wearing a helmet and harness. Not something I want to do on the street. Your head can travel a long distance during an impact, and hitting a metal bar (even padded with foam) without a helmet would hurt. Even a thick head like mine.
great info DG!! ![](/ubbthreads/images/graemlins/thumbs.gif)
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
[Re: NANKET]
#1371182
01/17/13 07:09 PM
01/17/13 07:09 PM
Posts: 1,281 WI
wannadrag
WI
How do you think a classic car would do against a newer car (2000's) in a crash? Answer it to yourself and then watch this and see if you were right.
http://www.youtube.com/watch?v=cJrXViFfMGk
I would like to see that test with a car that has 2 normal frame rails not saying the results would differ but would be interesting to see.Those impala type bodies up till aroud 64 has a frame sorta shaped like a X and would naturally fold up with a impact in the corner.
[Re: wannadrag]
#1371183
01/17/13 08:15 PM
01/17/13 08:15 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
New cars are built to absorb the crash in stages. Old cars have no such provision. A roll basic roll bar or different frame added to an old car would do little to help someone survive from the type of crash shown.
As for a backseat with a roll bar; that is just plain dangerous to the passengers. Seat belts in old cars are just not sufficient to keep you in place. Heads will bounce on most surfaces. A piece of steel tubing that is placed lower and closer to your head will crack your mellon, (padding will not help, a helmet will only marginally help).
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: dOc !]
#1371185
01/17/13 11:59 PM
01/17/13 11:59 PM
Posts: 9,162 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
DAMN ...
How solid was that Bel Air? Did you see the cloud of RED dust come out from under it? Would an insurance institute looking to prove a point fudge or overlook such a thing?
[Re: hudsonhornet7x]
#1371186
01/18/13 03:09 AM
01/18/13 03:09 AM
Posts: 989 WI, USA
67dodge67
mopar addict
mopar addict
WI, USA
I have a 68 charger that I am in the process of restoring and currently it is a stripped bare shell. I have always been interested in adding a roll bar/cage to it.
Does anyone know of a street friendly system that will allow access to the rear seat, and still allow easy access for drivers?
I am not too interested in building a jungle gym, just a good system to strenghten the car up. Also, at what point does the NHRA mandate a roll bar/cage?
Thanks for any help you can give,
HH
Contact S&W Race Cars for a roll bar kit for your car. I went with one for my Coronet after talking a several members on the race section. I chose to pull out my rear seat, however, I could have left it in and have had people squeeze in, if absolutely necessary. Here's a pic. I fabbed up the swing out bar for the driver's side. Never had any issues with tech either. Best wishes, Dave
[Re: Ramrod39]
#1371189
01/19/13 07:36 PM
01/19/13 07:36 PM
Posts: 5,395 Pikes Peak Country
TC@HP2
Pikes Peak Country
Exactly. That era of Bel-Air was an x frame design that had nothing but sheetmetal hanging out where the doors are.
That isn't to say our moaprs are a bunch better, but an X frame is no where near as good as a perimeter frame.
[Re: TC@HP2]
#1371190
01/19/13 07:42 PM
01/19/13 07:42 PM
TC@HP2
Pikes Peak Country
I was thinking of making the roof hoop so it would fit up tight to the roof just inside the roof structure,then padding it and putting the headliner over it so it is hidden. I was going to pad the roof with insulation to make it seamless. I was going to make the rear seat cross brace removable so it could come out when people are in the rear seat. It could be held in with cleavis pins,and have padded caps with snaps to fit over the recievers when not in use.
Hmmm. IF you could put the A and B piller uprights and the halo tucked up into the existing structure so tight they would fit under the existings panels, this could almost work. However, adding a cross bar behind the seats would kill it because you would have to leave a stub hanging out in space for the removeable bar to pin into. That is like just putting a target out there for someone to smash into and would actually, IMO, be more dangerous than a cross bar.
Like quickdodge said, it isn't the problem that you can pad a roll cage vs hitting the stock inner body structure. It is the fact that you signficantly reduce the space your bady has to stretch before hitting anything. If in stock form your head is 6" away from the roof sill, you have that far to move before making contact. By contrast, put a 1.5" round roll bar tube that is spaced 1" away from the sill to allow you welding access and now you only have 3.5" to allow for movement before striking a solid object. 6PKRTSE has a very nice cage in his car, but I'd hate to be in a hard street accident in it, especially with the funny car cage add in, because your melon will be a pinball inside all that tubing.
That isn't to say our mopars are a bunch better, but an X frame is no where near as good as a perimeter frame.
[Re: TC@HP2]
#1371191
01/22/13 08:55 AM
01/22/13 08:55 AM
Posts: 408 Manhattan, IL
SixPackRT
Manhattan, IL
I would go with a 6 point as stated earlier. You can always add a few points (pain yes, but possible). But a six point will get you what your looking for. I have one in a T-type I have and had the shop that installed it keep the side bars as low as they possibly could and still be safe (and legal). I didn't want a swing out bar because of rattles and for sake of being more rigid. Keep the bars going into the trunk as high as you can to allow as much access to the back seat as possible. I don't know what kits are on the market, but I would look at getting what you want done for your needs. Any good chassis guy/shop ought to be able to accommodate you. Also (its been a while) but chrome moly tubing will allow you to go with smaller diameter bars than mild steel if memory serves. ![](/ubbthreads/images/graemlins/thumbs.gif) Scott
70 Coronet RT 440+6 64 Dodge 330 - Future Hemi Clone 17 Challenger Hellcat - Green Go Driver 86 Buick T-Type Turbo V-6
[Re: SixPackRT]
#1371192
01/22/13 12:01 PM
01/22/13 12:01 PM
Posts: 11,688 W. Kentucky
justinp61
W. Kentucky
Scott
You can only use 1 5/8" cm on a roll cage, a 6 or 8 point roll bar has to be 1 3/4".
I have a 6 point bar with the pro street bars in my Dart. No one rides in the back seat, IMO it's to dangerous even in a minor accident.
