Re: 904 trans banging full throttle 1-2 upshift??
[Re: 70Challengerse]
#136843
10/20/08 08:30 AM
10/20/08 08:30 AM
Posts: 75,026 U.S.S.A.
JohnRR
U.S.S.A.
If the "momentarily dis-engaging" happens on a manual 1-2 upshift it's probably a case of severe overlap; on a manual upshift the rear band is slow to disengage and the trans is momentarily "in two gears" at once.
Exactly was I was thinking,I have in the past used a spring from a t-35 trans and install it in the rear band...works great and no over lap.
T-35 ???
