Re: realistic et goal for a 78 400
[Re: MPerry]
#1367640
01/11/13 11:54 AM
01/11/13 11:54 AM
Posts: 10,037 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I am assuming you are going to rebuild the shortblock with an over bore? Like the post on the 400 motor and MP cams shows, the more cam you put in it, the faster it will go. The limit is about the 590 cam. The 850 is a good choice for carb. Good machine work, file fit rings, as much compression as you can put in it, and 1 7/8 headers will all help. A solid lifter cam will allow more rpm giving more hp. One key is cylinder head prep. Bowl work and 2.14/ 1.81 valves will do a lot for the build. A good single plane manifold to match a 557 or 590 cam, and if you don't run high elevens something isn't right. This basic recipe put a 383 roadrunner into the low 12.0s at 3850 with a 268 @ .050 hydraulic 540 lift cam (stock stamped rockers!)that quit at 5600/6000 rpm due to valve float issues. You would have more cubes and a better cam if you go 557 or 590, and the ability to ring more hp out of it with more rpm.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: Dean_Kuzluzski]
#1367644
01/11/13 07:26 PM
01/11/13 07:26 PM
Posts: 11,657 Fitchburg,Massachusetts
MPerry
Mopahts memba'
Mopahts memba'
More time than money spells buy/borrow a die grinder and template/bowl port the 516's, mill and get guides/seats done.
I gained 3 mph through the traps when I ported my 516's. Well worth the time.
Great thread. Glad to see there's some of us old schoolers out there that are just trying to have some fun on a budget.
I have a nice die grinder where would I find the templates?
[Re: Mr.Yuck]
#1367645
01/12/13 12:02 AM
01/12/13 12:02 AM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
not going to get there with that combo. Maybe 13.50 for 12's you are going to need more compression, some head work... can you use the 413?
Hold up a sec, Mr. Y. You are forgetting he has an alternative to the longer arm of the 413. RPM potential!! He can spin it a bit less than a 383 to make power, (and a bit more than a 413) but overall make slightly better times than you posted. Mopar Muscle did a couple of builds on the 400 Mopar with very impressive results. Sure, the car could use a bit more gear, (4.10/4.30, cam depending) but for what he has already, he's almost there! The real power is in the cam and ignition timing and carb tuning. Not as easy as the 413, but you WILL be surprised when it's right!! Have to get carb/ignition spot-on for the combo to really fly!! Concerning the porting templates, Mancini or any major Chrysler Dealer sells them, the part number is P4120437, pretty reasonable.
![](/ubbthreads/images/graemlins/2245452-furysmiley.gif)
[Re: HYPER8oSoNic]
#1367646
01/12/13 12:55 AM
01/12/13 12:55 AM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
The real power is in the whole combination, but it's been my experience that a good set of heads is #1 in the combination.
[Re: 493_DART]
#1367647
01/12/13 01:05 AM
01/12/13 01:05 AM
moparmanjames
Las Vegas NV
Classic Moparts thread..........
with the parts listed and factory heads....
at 3700 lb .....high 12's.
at 3300 with the out -dated 509 / out dated iron heads / 3:91/410 gear / slicks/ etc... you can get to 12.20
I went 12.50's @ 110 in my 3700lb Roadrunner with 3.23 gears. I built a 440 with home ported 516 heads, 10:1 compression, 509 cam, solid 7 blade fan with stock accessories and a 3500 stall/727 on MT Sportsman pro's driving it to the track here in Las Vegas.
[Re: MPerry]
#1367648
01/12/13 03:12 AM
01/12/13 03:12 AM
Posts: 6,572 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Tunnel ram is for a low deck so it won't work for the 413. I have more time than money at the moment. I know the 413 runs well so I will leave it be.
I thought we were talking about a 400. ![](/ubbthreads/images/graemlins/shruggy.gif)
Kevin
[Re: Twostick]
#1367649
01/12/13 05:01 AM
01/12/13 05:01 AM
MPerry
Mopahts memba'
Mopahts memba'
Kevin
Yes the 400 is the intended subject. I would be able to use the tunnel ram on that. There was doubt about the 400 being capable of achieving the goal. That is how the 413 got mixed in the subject. ![](/ubbthreads/images/graemlins/wink.gif)
[Re: MPerry]
#1367653
01/13/13 10:05 PM
01/13/13 10:05 PM
HYPER8oSoNic
Desert Tracker
Takes a little bit of tuning work (on your part), but you'll hit the mark for sure. ![](/ubbthreads/images/graemlins/thumbs.gif) You'll have fun testing and tuning. Just remember to keep a SOLID baseline (reference point) BEFORE you tune!! ![](/ubbthreads/images/graemlins/2245452-furysmiley.gif)
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
[Re: MPerry]
#1367655
01/14/13 01:22 AM
01/14/13 01:22 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Well I'm going to give it a shot & find out. 12.50 or bust! ![](/ubbthreads/images/graemlins/penguin-006.gif) I will be able to bracket race it either way.
do a pocket port on the heads you want to use... thats real easy to do.... the conv will make a big difference as well as the chassis set up... if your looking to go 12.50 in the heat you need to make it run 12.30 in good air and I'm sure some of these guys are telling you the best they ran... you need more gear but use what you have... the 509 might get close with the porting... also do a match port to the intake and heads... with your die grinder knock out any chunks in the runners and just smooth up the short turn on the heads... if you can have the heads milled some to clean them and make them flat will help... get the front of the car as loose as possible so it lifts and get some rancho 9000 shocks for the rear and I think you'll get there.... use your 850 carb ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MPerry]
#1367656
01/14/13 12:14 PM
01/14/13 12:14 PM
gregsdart
I am not sure how well they will fit, but QUICKD100 had great success with a pair of Thermoquads on a Tunnelram Hemi. Might be a cheap alternative, and once dialed in, ought to run like scat!!! I am betting two tenths quicker than the best single plane deal. What I like about this combo is the small preimarys for cruise, and vacuum secondary's providing as much air as the combo will need for max power. As far as mounting, there is a way. Might need to get creative, but it can be done. I think I have two TQ to holley pattern adapters, and if you choose to try this combo, they are yours for the shipping. A couple of swap meet carbs, two rebuild kits and some jets and you are in business.
[Re: MR_P_BODY]
#1367657
01/14/13 12:17 PM
01/14/13 12:17 PM
MPerry
Mopahts memba'
Mopahts memba'
I have another 3rd member with 4.30's on a strange spool if you think that is better. ![](/ubbthreads/images/graemlins/shruggy.gif)
