Re: Article where they ran all the MP cams in the same car [Re: Sport440] #1366681
01/11/13 05:56 PM
01/11/13 05:56 PM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
from memory I was of the understandig Bill Bagshaw used a 3800 J converter, it was the hot ticket of the times
Re: Article where they ran all the MP cams in the same car [Re: shoebox] #1366682
01/12/13 05:29 AM
01/12/13 05:29 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
A friend ran a low compression 400 with a fairly large cam, and it ran good. The car also had an 8" converter, and 4.88:1 gears, so it's not a dog when operating at 4,000+ RPM
Reminds me of Mopar Muscles' 400 HP 318 with no dyno numbers below 3,000 RPM, but at 3,000 RPM torque was 332, and jumped 44 ft/lbs to 376 @ 3,500 RPM?
Re: Article where they ran all the MP cams in the same car [Re: 451Mopar] #1366683
02/09/13 03:30 PM
02/09/13 03:30 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Here is the article from Hi Performance Cars magazine published some time in '78. If these aren't clear enough then I will scan it and repost. The right mouse key isn't working here at the library so I can't rotate the pictures.
Re: Article where they ran all the MP cams in the same car [Re: 446acuda] #1366684
02/09/13 03:33 PM
02/09/13 03:33 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
2
Re: Article where they ran all the MP cams in the same car [Re: 446acuda] #1366685
02/09/13 03:33 PM
02/09/13 03:33 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
3
Re: Article where they ran all the MP cams in the same car [Re: 446acuda] #1366686
02/09/13 03:34 PM
02/09/13 03:34 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Re: Article where they ran all the MP cams in the same car [Re: 446acuda] #1366687
02/12/13 09:11 PM
02/12/13 09:11 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
nice read..
Re: Article where they ran all the MP cams in the same car [Re: earthmover] #1366688
02/13/13 01:36 PM
02/13/13 01:36 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Haven't read about 50' times too much lately! When did the 60' become the standard measure of launch quickness?
Good read but is this the article the OP was talking about? I was hoping to see the .557 cam but the spring pack they used couldn't handle it.
Re: Article where they ran all the MP cams in the same car [Re: radar] #1366689
02/26/13 07:29 PM
02/26/13 07:29 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Here is a scanned version for easier reading (even though it is the wrong article )
7604542-DCduster.PDF (298 downloads)
Re: Article where they ran all the MP cams in the same car [Re: 446acuda] #1366690
02/26/13 09:04 PM
02/26/13 09:04 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I took those articles as gospel in the day. Today, not so much.
Sheldon
Re: Article where they ran all the MP cams in the same car [Re: 67Satty] #1366691
02/28/13 07:27 PM
02/28/13 07:27 PM
organ
maximum entropy Offline
organ
Makes my want to try the MP 557 cam some day. Do the old MP grinds make less valve train racket than the newer more aggressive profiles?
i had a 557 in my scamp for a while. the clatter was UNBELIEVABLE. it didn't matter how tight i ran it. i put a 509 in, and the car is way lopier, quieter, and faster.
Re: Article where they ran all the MP cams in the same car [Re: 446acuda] #1366692
03/01/13 07:42 PM
03/01/13 07:42 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
446acuda,
THANKS so much for scanning that article. It made it much easier for me to read!
That is such a cool combo. You can really tell where the aftermarket parts were directed to at that time. Lots of production/used parts that were readily available on a budget got into the mix. An 8&1/4 rearend with an 11 sec motor!! Cast iron intake, factory converter, a TQ, and the old garden variety (used to hold up your tomato plant) MP 484 and 509 bumpsticks!!
Doesn't seem like anyone would dare to leave home with a set-up like that today!
Got a similar pkg to pull together for a J-body here at the moment.
Re: Article where they ran all the MP cams in the same car [Re: Dean_Kuzluzski] #1366693
03/02/13 01:17 AM
03/02/13 01:17 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
This is the direction I'm going with my 67 Coronet: smog 400, ported stock heads heavily milled for some compression, 509 cam, M1 single plane, 4.10 gears and a hi stall. Cheap way to get a decently quick car
