Re: Article where they ran all the MP cams in the same car
[Re: shoebox]
#1366682
01/12/13 05:29 AM
01/12/13 05:29 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
A friend ran a low compression 400 with a fairly large cam, and it ran good. The car also had an 8" converter, and 4.88:1 gears, so it's not a dog when operating at 4,000+ RPM ![](/ubbthreads/images/graemlins/hammer.gif) Reminds me of Mopar Muscles' 400 HP 318 with no dyno numbers below 3,000 RPM, but at 3,000 RPM torque was 332, and jumped 44 ft/lbs to 376 @ 3,500 RPM?
[Re: 446acuda]
#1366692
03/01/13 07:42 PM
03/01/13 07:42 PM
Posts: 8,943 Holly/MI
Dean_Kuzluzski
Holly/MI
446acuda, THANKS so much for scanning that article. It made it much easier for me to read! ![](/ubbthreads/images/graemlins/thumbs.gif) That is such a cool combo. You can really tell where the aftermarket parts were directed to at that time. Lots of production/used parts that were readily available on a budget got into the mix. An 8&1/4 rearend with an 11 sec motor!! Cast iron intake, factory converter, a TQ, and the old garden variety (used to hold up your tomato plant) MP 484 and 509 bumpsticks!! ![](/ubbthreads/images/graemlins/laugh2.gif) Doesn't seem like anyone would dare to leave home with a set-up like that today! ![](/ubbthreads/images/graemlins/biggrin.gif) Got a similar pkg to pull together for a J-body here at the moment.
[Re: Dean_Kuzluzski]
#1366693
03/02/13 01:17 AM
03/02/13 01:17 AM
Posts: 4,258 Canada
WO23Coronet
Canada
This is the direction I'm going with my 67 Coronet: smog 400, ported stock heads heavily milled for some compression, 509 cam, M1 single plane, 4.10 gears and a hi stall. Cheap way to get a decently quick car
