Re: Indy or Shady Dell?
[Re: J_BODY]
#1365677
01/08/13 12:03 PM
01/08/13 12:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Hind sight is 20/20 Steve. As James noted, the only "craftsmanship" issues I possibly had was the cracking around the guides, and like I stated before, it was either an assembly error, or trying to press a guide into material that resembled a fortune cookie. I cannot make that call....machinist im not....and would you be happy sending your head to a "professional" for a repair and the epoxy comes out after 150 passes?? Once again...I'm not an expert in this field, that's why I rely on people "in the know" to handle these situations. Perhaps it wasn't made clear to me that the epoxy repair was a "maybe it will work, maybe it won't" deal. These were the supposed "good" blue core plug heads. I had another set of W5's, but sold them in anticipation of the Ebrock super victor head. Those heads seemed to have a better visual finish, but at that point I'd had enough of MP heads. We ran Stage VI's on my big block.....I'm a glutton for punishment I guess. We actually were building a W2 mill, but those had some cracks in them (quite common from what i've seen) and I went with the W5 under the guise that "aluminum heads are repairable". Live and learn.
9.87 was run at Oahe Speedway Jim...
The alum heads are repairable to a certain extent but the W-5s were basically so bad with porosity its hard to weld when you run into dirt in the castings... I have had 2 sets of W-5s and the first(old castings) had holes in them when I got them...being that I worked at Chrysler Engineering I talked to the rep at a car show and he said he would swap them out... and when I showed him them he said.... keep them and gave me the new castings... I started playing with port work on them to get the numbers up and then I sold them to Vic on here so he could play with them... Ryan did a real nice job of hand porting my W-9s and they flowed the same as my Chapman CNC set of W-9s (I flowed both sets at work on the same bench). I've had bad luck on different companies on different work and now I go to a local company called St Clair Engine and Sean has taken good care of my junk
[Re: Al_Alguire]
#1365678
01/08/13 12:30 PM
01/08/13 12:30 PM
Posts: 252 St.Louis, Mo.
mokid
St.Louis, Mo.
Well I think my position on the subject has been well documented over the years so I wont rehash it. But if it were me like mokid said I would be looking elswhere. Mopar guys sure get hung up on using "mopar only" shops. There are plenty of compitent shops out there that can do the work. Afterall .0001" is .0001" whether it is Ford Chvy or Mopar. A good machinist ot head guy is a good machinist or head guy period. The fact some here are poo pooing a $30K all out effort does not surprise me either. Some just have no idea what it costs to actually build an all out effort.
Thanks Bro for that, We are currently on a up grade rebuild new rod,pistons,lifters, and the shop doing work does mostly chevy race motors in fact he said my motor is more like a chevy then mopar, chevy crank, chevy rods, ford firing order, oh buy the way this shop fixed all the screw ups that one of the noted builders from PA did.
[Re: mokid]
#1365679
01/08/13 12:57 PM
01/08/13 12:57 PM
dartman366
Mt. Vernon, Ohio
Been there, done that,,I have a local guy that does all my work now and he is also well versed in the GM stuff, but he also has a BB mopar customer that is sitting on a NHRA stock class record as we speak, so he knows his Mopars too and how they work, plus he has pulled my but out of a jam on several occations with my present motor and got it straightened up.
[Re: dartman366]
#1365680
01/08/13 01:45 PM
01/08/13 01:45 PM
Posts: 19,398 Las Vegas
Al_Alguire
Las Vegas
Well FWIW both my engines has HAND ported heads. The B1's and Pro Stock peices are both hand ported and seem to make pretty good power..
As for engine builders I have pimped my guy here many times. I have a 1050hp b1 that works like a xerox machine and he is NOT a Mopar engine guy. But he does build some of the fastest cars out in this part of the country. Also this little shop in Phoenix called RWR has a pretty good reputation.....
[Re: mokid]
#1365682
01/08/13 03:24 PM
01/08/13 03:24 PM
Posts: 331 O'Fallon,IL.
70RTRacer
O'Fallon,IL.
Chris and Al,
You are both dead on. Chris and I are both using the same builder. I couldn't be happier.
[Re: moparguy7074]
#1365686
01/10/13 04:51 AM
01/10/13 04:51 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
I have a question, why is a cnc port job better than a hand port job?
It really depends on who's doing the work. A hand ported set of heads can work around core shift and other inconsistencies in the head if the person handling the grinder is any good. At the same time, if the CNC program is a good one (NOT Patriot performance.. Is it bad to name names??) then the result is a set of heads that flow very very well much quicker than a comparable set of hand ported heads. When it comes right down to it though, for max effort, I think hand porting is the way to go. After all, the CNC port is just a copy of a hand ported port.
[Re: dodgeboy11]
#1365688
01/12/13 08:26 AM
01/12/13 08:26 AM
Posts: 4,085 Mo.
racerx
Mo.
With that said who would one recommend for an good cnc program for the s/b,BB heads
[Re: racerx]
#1365689
01/12/13 09:54 AM
01/12/13 09:54 AM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
the what?
[Re: joshking440]
#1365691
01/13/13 10:28 PM
01/13/13 10:28 PM
Posts: 4,085 Mo.
racerx
Mo.
the what?
Who has an nice cnc program for the sb/bb heads?
[Re: 1967dartgt]
#1365694
01/14/13 07:56 AM
01/14/13 07:56 AM
Posts: 4,085 Mo.
racerx
Mo.
the what?
Which small block head and which bb head? There are a lot of heads out there and not one shop will have all those different cnc programs.
Sorry -1s never mind on the s/b heads.
[Re: 1967dartgt]
#1365696
01/14/13 09:19 PM
01/14/13 09:19 PM
Posts: 4,085 Mo.
racerx
Mo.
the what?
Slawko for big blocks
Thaxs do they have an website,contact#?
