Re: Flow testing carburetors... * DATA ADDED *
[Re: tboomer]
#1363886
01/14/13 12:26 PM
01/14/13 12:26 PM
BradH
...Put the damn thing together already!!
Yep, back to working on the engine. The next steps that come to mind are... - degree the cam and... - find out what the length of the new pushrods need to be, then... - assemble the heads.
[Re: MPerry]
#1363888
01/14/13 05:40 PM
01/14/13 05:40 PM
Posts: 2,490 Sydney,Australia
tex013
Sydney,Australia
Brad, thanks for the post/info.i guess it does show that you can only compare carbs based on their specifications,venturi/throttle size,not what the manufacturer calls them
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: BradH]
#1363891
01/15/13 12:46 AM
01/15/13 12:46 AM
Posts: 1,462 oklahoma
forphorty
oklahoma
I did this for myself, not for Moparts, but am still a bit surprised by the lack of any related comments.
Is the lack of response to this post (despite over 1000 hits) due to the what seems to be a continuing trend on this forum that "tech is boring", or because all of about four people on this board thought this data was even worth discussing?
I appreciate the info. Pretty interesting stuff . I would be interested in seeing how various modifications affect cfm. Example: a stock street type carb flowed OOTB, then with the choke tower chopped off,then thinned shafts and button head butterfly screws, etc.
[Re: Sport440]
#2428723
01/04/18 04:03 AM
01/04/18 04:03 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
When I made my flow bench I used a 4150 pattern to mount my bore adapter to. So I have just flowed carbs all 4 bbls all at once.
One day Im on the phone with Eddie Miller, he is telling me he is putting 2 90mm throttle bodies on his tunnel ram. Says they flow 1100 cfm each. Im like BS, no way. Hold on, I have a 90 here. Throw it on my bench. 1086. Wow. Ok
On the phone with Thumper, i ask him what a particular carb I have is supposed to flow, he said he thinks 1200. I throw it on the bench and it reads 1168 or something. Ok
You just tested a bunch on the dyno which seems to be a much better indicator of what might work best unless to much data has you scratching your head from that test session
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: BradH]
#2428838
01/04/18 01:00 PM
01/04/18 01:00 PM
Posts: 14,531 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
When I flow a carb, I test all barrels individually, then add the numbers together. 4bbl carbs are rated at 1.5"hg test pressure, which is like 20.4"h2o. I could probably pull 20.4" of pressure flowing 2bbls at a time for most 4150 carbs, but I'd have to make a different fixture to do it that way. I very rarely flow test carbs anymore. Pick the size you feel you need....... Then most of the power is in the metering. To that point: You just tested a bunch on the dyno which seems to be a much better indicator of what might work best unless to much data has you scratching your head from that test session Of the carbs we ran on Brads motor, only one had the metering off far enough where we couldn't make pulls without fear of doing some damage. Of the other carbs tested, the one with the smallest venturi(and least flow) made as much power as any of the others. It was doing a better job of mixing the fuel.
[Re: BradH]
#2429688
01/05/18 11:39 PM
01/05/18 11:39 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I wish someone would build a billet carb base that has a built in shear plate bottoms...maybe you could test a shear plate vs a regular carb bottom?
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: moparx]
#2429947
01/06/18 02:35 PM
01/06/18 02:35 PM
BradH
Ever considered flow a couple of TQ’s?
i really like those carbs, and that would be of interest to me as well. Sorry folks, but this is really old data... 5 years. I won't be doing any carb flow bench testing in the foreseeable future, nor do I have a spreadbore test fixture for a TQ.
[Re: BradH]
#2430030
01/06/18 04:26 PM
01/06/18 04:26 PM
fast68plymouth
So. Burlington, Vt.
If you want what I would consider even close to "accurate" flow data from carbs, they really should be flowed with all barrels at the same time, at full capacity(1.5"hg). And that means you need a big honkin flow bench.
And even better yet....... Wet flow tested.
