Page 2 of 3 1 2 3
Re: Flow testing carburetors... * DATA ADDED * [Re: BradH] #1363882
01/12/13 01:05 PM
01/12/13 01:05 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Is it common for carbs to be off much from their advertised cfm?
Re: Flow testing carburetors... * DATA ADDED * [Re: MPerry] #1363883
01/12/13 01:08 PM
01/12/13 01:08 PM
tboomer Offline
tboomer  Offline
Neat testing,Brad! You are thinking outside of the bun again! But come on....Put the damn thing together already!!
Re: Flow testing carburetors... * DATA ADDED * [Re: tboomer] #1363884
01/14/13 11:23 AM
01/14/13 11:23 AM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I did this for myself, not for Moparts, but am still a bit surprised by the lack of any related comments.
Is the lack of response to this post (despite over 1000 hits) due to the what seems to be a continuing trend on this forum that "tech is boring", or because all of about four people on this board thought this data was even worth discussing?
Re: Flow testing carburetors... * DATA ADDED * [Re: BradH] #1363885
01/14/13 11:25 AM
01/14/13 11:25 AM
tboomer Offline
tboomer  Offline
I did find it interesting!
Re: Flow testing carburetors... * DATA ADDED * [Re: tboomer] #1363886
01/14/13 11:26 AM
01/14/13 11:26 AM
BradH Offline OP
BradH  Offline OP
Yep, back to working on the engine. The next steps that come to mind are...
- degree the cam and...
- find out what the length of the new pushrods need to be, then...
- assemble the heads.
Re: Flow testing carburetors... * DATA ADDED * [Re: BradH] #1363887
01/14/13 11:40 AM
01/14/13 11:40 AM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Well its easy to be interested. That is why so many views. Its harder to understand what is being done. Myself included. When I see flow data it is usually cylinder heads.
Re: Flow testing carburetors... * DATA ADDED * [Re: MPerry] #1363888
01/14/13 04:40 PM
01/14/13 04:40 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Brad,
thanks for the post/info.i guess it does show that you can only compare carbs based on their specifications,venturi/throttle size,not what the manufacturer calls them
Tex
New best ET 10.259@129.65 .
New best MPH 130.94
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Flow testing carburetors... * DATA ADDED * [Re: BradH] #1363889
01/14/13 08:38 PM
01/14/13 08:38 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I too find it interesting, and appreciate the info, but don't know what to make of it either.
I've wondered about the 1.56/1.60 venturi 4150 carbs, and the flow restriction contribution from the throttle shaft and throttle plate. Ideally, the only restriction would the venturi and booster. So, I would find it interesting to see the same tests without the shafts/plates. Not sure what the value of that would be either.
Re: Flow testing carburetors... * DATA ADDED * [Re: BSB67] #1363890
01/14/13 10:55 PM
01/14/13 10:55 PM
Renton Washington
Triple Threat Offline
Renton Washington
/quote]
I think that about sums it up for the average reader. I look forward to an on track comparison as well!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Flow testing carburetors... * DATA ADDED * [Re: BradH] #1363891
01/14/13 11:46 PM
01/14/13 11:46 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I appreciate the info. Pretty interesting stuff . I would be interested in seeing how various modifications affect cfm. Example: a stock street type carb flowed OOTB, then with the choke tower chopped off,then thinned shafts and button head butterfly screws, etc.
Re: Flow testing carburetors... * DATA ADDED * [Re: BradH] #2428513
01/03/18 08:50 PM
01/03/18 08:50 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
I was looking all over the web for this info, it was right here the whole time.
Thanks BradH for doing this test!
Re: Flow testing carburetors... * DATA ADDED * [Re: 65Fury440] #2428671
01/04/18 12:57 AM
01/04/18 12:57 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Same here.
Re: Flow testing carburetors... * DATA ADDED * [Re: Sport440] #2428723
01/04/18 03:03 AM
01/04/18 03:03 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
When I made my flow bench I used a 4150 pattern to mount my bore adapter to. So I have just flowed carbs all 4 bbls all at once.
One day Im on the phone with Eddie Miller, he is telling me he is putting 2 90mm throttle bodies on his tunnel ram. Says they flow 1100 cfm each. Im like BS, no way. Hold on, I have a 90 here. Throw it on my bench. 1086. Wow. Ok
On the phone with Thumper, i ask him what a particular carb I have is supposed to flow, he said he thinks 1200. I throw it on the bench and it reads 1168 or something. Ok
You just tested a bunch on the dyno which seems to be a much better indicator of what might work best unless to much data has you scratching your head from that test session
Re: Flow testing carburetors... * DATA ADDED * [Re: BradH] #2428838
01/04/18 12:00 PM
01/04/18 12:00 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
When I flow a carb, I test all barrels individually, then add the numbers together.
4bbl carbs are rated at 1.5"hg test pressure, which is like 20.4"h2o.
I could probably pull 20.4" of pressure flowing 2bbls at a time for most 4150 carbs, but I'd have to make a different fixture to do it that way.
I very rarely flow test carbs anymore.
Pick the size you feel you need....... Then most of the power is in the metering.
To that point:
Of the carbs we ran on Brads motor, only one had the metering off far enough where we couldn't make pulls without fear of doing some damage.
Of the other carbs tested, the one with the smallest venturi(and least flow) made as much power as any of the others.
It was doing a better job of mixing the fuel.
Re: Flow testing carburetors... * DATA ADDED * [Re: BradH] #2429688
01/05/18 10:39 PM
01/05/18 10:39 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I wish someone would build a billet carb base that has a built in shear plate bottoms...maybe you could test a shear plate vs a regular carb bottom?
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Flow testing carburetors... * DATA ADDED * [Re: BradH] #2429700
01/05/18 11:01 PM
01/05/18 11:01 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Just caught this thread.
Ever considered flow a couple of TQ’s?
Re: Flow testing carburetors... * DATA ADDED * [Re: Rob C] #2429867
01/06/18 11:40 AM
01/06/18 11:40 AM
moparx Offline
moparx  Offline
i really like those carbs, and that would be of interest to me as well.
beer
Re: Flow testing carburetors... * DATA ADDED * [Re: moparx] #2429947
01/06/18 01:35 PM
01/06/18 01:35 PM
BradH Offline OP
BradH  Offline OP
beer
Sorry folks, but this is really old data... 5 years. I won't be doing any carb flow bench testing in the foreseeable future, nor do I have a spreadbore test fixture for a TQ.
Re: Flow testing carburetors... * DATA ADDED * [Re: BradH] #2430009
01/06/18 02:47 PM
01/06/18 02:47 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
It would be interesting to know what the actual flow is of the different aftermarket main bodies available. That would be some great data.........
Re: Flow testing carburetors... * DATA ADDED * [Re: BradH] #2430030
01/06/18 03:26 PM
01/06/18 03:26 PM
So. Burlington, Vt.
So. Burlington, Vt.
If you want what I would consider even close to "accurate" flow data from carbs, they really should be flowed with all barrels at the same time, at full capacity(1.5"hg).
And that means you need a big honkin flow bench.
And even better yet....... Wet flow tested.
Page 2 of 3 1 2 3
