Page 3 of 3 1 2 3
Re: Milodon 31580 Road Race Pan Help [Re: jbc426] #1363596
03/03/15 12:18 AM
03/03/15 12:18 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Not sure if this info is helpful, but the pan fits in my 1970 e-body with 2 inch TTi's. The scattershield is more of a concern with the pan in my case. The pan has to be installed and the engine put in sans bellhousing and clutch to clear the k-member.
I ran into this exact same problem with my 74 Challenger, small block, 1 3/4 Hookers, and the Milodon road race pan. The pan sump is so freaking big, I couldn't get enough angle with the trans and bell housing in place to get it all wiggled down in between the motor mount blocks.
Once I drop the trans and bell housing, it dropped right in. Its a plenty snug fit, but it doesn't touch anywhere and nothing hits it, although I do have a single header tube within 1/2" on the passenger side.
Re: Milodon 31580 Road Race Pan Help [Re: TC@HP2] #1363597
03/03/15 01:21 PM
03/03/15 01:21 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I went from the bottom up in my 68 charger with a 4 speed. No problems except for valve cover hitting the frame. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Milodon 31580 Road Race Pan Help [Re: lewtot184] #1363598
03/03/15 08:01 PM
03/03/15 08:01 PM
Norcal
W
Wildjones Offline
Wildjones  Offline
W
Norcal
Sorry to dig this up, but can anyone point me in the right direction for something to block off the oil temp sender bung? I'm not certain what the threads are, nor where to look for such a thing?
Thanks!
1/2" pipe plug.
So if I bought something like this http://m.summitracing.com/parts/prs-1020 would I also need an o ring or something to seal? sorry for the rookie question.
Re: Milodon 31580 Road Race Pan Help [Re: Wildjones] #1363599
03/03/15 08:19 PM
03/03/15 08:19 PM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
No, use teflon thread sealant. NPT means National Pipe Tapered, meaning the deeper it is screwed in the tighter it gets. NPS is straight thread and would require a sealing feature like an o-ring or sealing washer.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: Milodon 31580 Road Race Pan Help [Re: 67Charger] #1363600
03/03/15 08:53 PM
03/03/15 08:53 PM
Norcal
W
Wildjones Offline
Wildjones  Offline
W
Norcal
Awesome explanation, thank you!
Page 3 of 3 1 2 3
