Re: How Many Runs Did You Get In This Year?
[Re: Bad340fish]
#1362232
01/01/13 12:01 AM
01/01/13 12:01 AM
Posts: 7,506 Az
Crizila
Az
Right around 40 passes this year.
Fastest 300
[Re: Dabee]
#1362235
01/01/13 04:34 AM
01/01/13 04:34 AM
Posts: 19,391 Las Vegas
Al_Alguire
Las Vegas
The usual. About 100+- in two cars. Dont race much outside of divisional stuff anymore.
[Re: Crizila]
#1362238
01/01/13 12:28 PM
01/01/13 12:28 PM
Posts: 3,842 N.E. Ohio
6bblFLASH
N.E. Ohio
17 in the Cuda 9 in the Satellite
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#1362239
01/01/13 01:02 PM
01/01/13 01:02 PM
Posts: 148 Montgomery, PA
dodge340dart
Montgomery, PA
I made 155 passes this year, 13 finals with 9 wins; I tied my best for wins in a season. Even better only three first round losses all year, that is important when you chase points. But the best I won the Outlaw Street track Championship for the 2nd year in a row at Beaver Springs Dragway, this year leading wire-to-wire.
Chris
2011 & 2012 Beaver Springs Dragway Outlaw Street Champion
2012 BSD Friday Street Racer Driver of the Year
3-time Jr. Stock Eliminator
2-time Mean Street Eliminator
'69 340 Dart 1.500 60ft, 11.359et, 117.08mph
[Re: Quicktree]
#1362242
01/01/13 03:17 PM
01/01/13 03:17 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
I had about 25 total for the year, which for my street/strip car. I think is a lot. If I keep going down this route. I might need to start taking thismore serious. Mike
1969 Dodge Dart Swinger
[Re: TheTieWrapKid]
#1362244
01/01/13 04:23 PM
01/01/13 04:23 PM
Posts: 52,972 Romeo MI
MR_P_BODY
One trip this fall 1/8 mile with the 4 speed 69 Dart - A couple of 8.30s and an 8.20ish. Bad 60 ft of around 2.0. My cheapo front drag shocks and rear air shocks with super stock springs ain't doing it ! Ideas encouraged about hooking up with super stock springs. I do have front Konis to try back on there. Happy New Year !!!
Your NEVER gonna 60' with junk shocks... air shocks are the WORST thing you want with any SS spring (any spring for that matter) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: TheTieWrapKid]
#1362245
01/01/13 05:32 PM
01/01/13 05:32 PM
Posts: 1,271 Vista, California
67Satty
Vista, California
I run Super Stock springs with cheap Monroematic shocks made for a Dodge D150 pickup on the back. 1.71 60 foot so far. Maybe try some of these shocks, they are cheap enough to be worth a try to get rid of those air shocks.
[Re: 67Satty]
#1362246
01/01/13 07:02 PM
01/01/13 07:02 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I used to use the long mopar performance drag shocks with SS springs on my Demon. It had a best 60 ft. of 1.36.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: TheTieWrapKid]
#1362248
01/01/13 08:24 PM
01/01/13 08:24 PM
MR_P_BODY
I've run the car with the Mopar 4 speed long shocks - probably 1.80s. I hit a best of 1.78 or so with the Koni fronts and air shocks in the back. I was trying Summit white front shocks to settle down the handling, which it did but they don't rise as much as the Konis. I had switched from bias ply to radial front tires which helped the handling so I can probably go back to a more aggressive front drag shock. I have been home porting and tweaking a little on my old cast crank 340 and the power is up some. But the 60 ft is at an all time worst. LOL. I had set aside some gas shocks from my 1500 truck in case that might work. I didn't know if they would fit on there just right. It might be fun to try them also. Something easily adjustable like a QA1 would be nice on rear to tune easily. Oh,one more thing : I have new slicks on there, the same as I had used before ( 9 x 28 MT same compound ). Anyway, thanks, and back to our regularly scheduled program !
With your port work your (most likely) making more power and when you make more power the shocks are even a BIGGER factor... for some reason people tend to think as soon as I make more power I will get a better 60'... well that works backwards(you just spin longer).. the QA-1s are a decent shock for the money... I run the OLD 12 way QA-1s and am very happy... also get a quality set of front shocks... if your Koni's are adjustable.. try them ![](/ubbthreads/images/graemlins/wave.gif)
[Re: qwkmopardan]
#1362250
01/01/13 11:59 PM
01/01/13 11:59 PM
Posts: 2,177 ill
dennismopar73
ill
582 total. 438 in the Lebaron, 103 in the Demon, 10 in the 79 "300", 9 in the 09 Challenger and 22 in the beat up 5 speed 1990 Ram 150 shop truck, {low 13 sec.] playing on wed nights.
19 Finals---12 wins--7 R/U--9 semis--12 1/4s
Beat up on a lot of Chevys and Fords this year!
![](http://i151.photobucket.com/albums/s153/johnsmith_45/08-29-09113_w.jpg)
![](http://i151.photobucket.com/albums/s153/johnsmith_45/_UTF-8_B_X01HXzAxMDkuSlBH_-3.jpg)
I didn't get to many,, 15 in the coronet 12 in my duster Dan you are the most noted toughest racer in the area,! look forward to your words of wisdom for me this coming year !! HAPPY NEW YEAR !!
