Page 2 of 3 1 2 3
Re: How Many Runs Did You Get In This Year? [Re: Bad340fish] #1362232
01/01/13 12:01 AM
01/01/13 12:01 AM
Az
Crizila Offline
Crizila  Offline
Az
Right around 40 passes this year.
Fastest 300
Re: How Many Runs Did You Get In This Year? [Re: Crizila] #1362233
01/01/13 01:07 AM
01/01/13 01:07 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
228 passes in the race car, plus 6 in my truck. I missed the first 5 races (times two classes, total of 10 races) due to knee surgery. I couldn't climb in & out of my race car, so I tried to compete im my truck. That was a total failure.
Won two races, RU in another. OK year.
Brian Dunnigan
Re: How Many Runs Did You Get In This Year? [Re: '72CudaRacer] #1362234
01/01/13 04:22 AM
01/01/13 04:22 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
250 passes in Da Beast and 6 in the RED.
Re: How Many Runs Did You Get In This Year? [Re: Dabee] #1362235
01/01/13 04:34 AM
01/01/13 04:34 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The usual. About 100+- in two cars. Dont race much outside of divisional stuff anymore.
Re: How Many Runs Did You Get In This Year? [Re: Al_Alguire] #1362236
01/01/13 12:03 PM
01/01/13 12:03 PM
New York
1stBxMopar Offline
1stBxMopar  Offline
New York
About 50 passes before a main bearing decided to shorten my season...
Was having a decent year up until then too, had fun with family and friends it was all good......
Re: How Many Runs Did You Get In This Year? [Re: 1stBxMopar] #1362237
01/01/13 12:25 PM
01/01/13 12:25 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
2012 was our year to get back out after parking the car in 08. Started our year off in Bakersfield for the March Meet where we made four test runs, and four rounds of eliminations. Every hit except the run where I went out had pretty much the same 60ft time....car was killer, and then two weeks later I hauled to MaTS so it could be delivered to it's new owner. Didn't see that coming, but it was a good 28 year run.
Re: How Many Runs Did You Get In This Year? [Re: Crizila] #1362238
01/01/13 12:28 PM
01/01/13 12:28 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
17 in the Cuda
9 in the Satellite
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: How Many Runs Did You Get In This Year? [Re: 6bblFLASH] #1362239
01/01/13 01:02 PM
01/01/13 01:02 PM
Montgomery, PA
dodge340dart Offline
Montgomery, PA
I made 155 passes this year, 13 finals with 9 wins; I tied my best for wins in a season. Even better only three first round losses all year, that is important when you chase points. But the best I won the Outlaw Street track Championship for the 2nd year in a row at Beaver Springs Dragway, this year leading wire-to-wire.
Chris
2011 & 2012 Beaver Springs Dragway Outlaw Street Champion 2012 BSD Friday Street Racer Driver of the Year 3-time Jr. Stock Eliminator 2-time Mean Street Eliminator '69 340 Dart 1.500 60ft, 11.359et, 117.08mph
Re: How Many Runs Did You Get In This Year? [Re: dodge340dart] #1362240
01/01/13 01:58 PM
01/01/13 01:58 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
None for me, but my motor made 135 passes in RBDuster's Aries.
Re: How Many Runs Did You Get In This Year? [Re: cgall] #1362241
01/01/13 02:09 PM
01/01/13 02:09 PM
Q
Quicktree Offline
Quicktree  Offline
Q
around 250 and second place in points by 1 round
Re: How Many Runs Did You Get In This Year? [Re: Quicktree] #1362242
01/01/13 03:17 PM
01/01/13 03:17 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
I had about 25 total for the year, which for my street/strip car. I think is a lot. If I keep going down this route. I might need to start taking thismore serious.
Mike
1969 Dodge Dart Swinger
Re: How Many Runs Did You Get In This Year? [Re: 67Satty] #1362243
01/01/13 03:52 PM
01/01/13 03:52 PM
North Texas
TheTieWrapKid Offline
North Texas
One trip this fall 1/8 mile with the 4 speed 69 Dart - A couple of 8.30s and an 8.20ish. Bad 60 ft of around 2.0. My cheapo front drag shocks and rear air shocks with super stock springs ain't doing it ! Ideas encouraged about hooking up with super stock springs. I do have front Konis to try back on there. Happy New Year !!!
Re: How Many Runs Did You Get In This Year? [Re: TheTieWrapKid] #1362244
01/01/13 04:23 PM
01/01/13 04:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your NEVER gonna 60' with junk shocks... air shocks
are the WORST thing you want with any SS spring
(any spring for that matter)
Re: How Many Runs Did You Get In This Year? [Re: TheTieWrapKid] #1362245
01/01/13 05:32 PM
01/01/13 05:32 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
I run Super Stock springs with cheap Monroematic shocks made for a Dodge D150 pickup on the back. 1.71 60 foot so far. Maybe try some of these shocks, they are cheap enough to be worth a try to get rid of those air shocks.
Re: How Many Runs Did You Get In This Year? [Re: 67Satty] #1362246
01/01/13 07:02 PM
01/01/13 07:02 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I used to use the long mopar performance drag shocks with SS springs on my Demon. It had a best 60 ft. of 1.36.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: How Many Runs Did You Get In This Year? [Re: 67Satty] #1362247
01/01/13 08:12 PM
01/01/13 08:12 PM
North Texas
North Texas
I've run the car with the Mopar 4 speed long shocks - probably 1.80s. I hit a best of 1.78 or so with the Koni fronts and air shocks in the back. I was trying Summit white front shocks to settle down the handling, which it did but they don't rise as much as the Konis. I had switched from bias ply to radial front tires which helped the handling so I can probably go back to a more aggressive front drag shock. I have been home porting and tweaking a little on my old cast crank 340 and the power is up some. But the 60 ft is at an all time worst. LOL. I had set aside some gas shocks from my 1500 truck in case that might work. I didn't know if they would fit on there just right. It might be fun to try them also. Something easily adjustable like a QA1 would be nice on rear to tune easily. Oh,one more thing : I have new slicks on there, the same as I had used before ( 9 x 28 MT same compound ). Anyway, thanks, and back to our regularly scheduled program !
Re: How Many Runs Did You Get In This Year? [Re: TheTieWrapKid] #1362248
01/01/13 08:24 PM
01/01/13 08:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With your port work your (most likely) making more
power and when you make more power the shocks are even
a BIGGER factor... for some reason people tend to think
as soon as I make more power I will get a better 60'...
well that works backwards(you just spin longer)..
the QA-1s are a decent shock for the money... I run
the OLD 12 way QA-1s and am very happy... also get
a quality set of front shocks... if your Koni's are
adjustable.. try them
Re: How Many Runs Did You Get In This Year? [Re: MR_P_BODY] #1362249
01/01/13 11:29 PM
01/01/13 11:29 PM
Outside
thedriver Offline
thedriver  Offline
Outside
4, in a 4 speed Pontiac.
1973 challenger
Dana. 4 speed. Low deck.
Re: How Many Runs Did You Get In This Year? [Re: qwkmopardan] #1362250
01/01/13 11:59 PM
01/01/13 11:59 PM
ill
dennismopar73 Offline
ill
582 total. 438 in the Lebaron, 103 in the Demon, 10 in the 79 "300", 9 in the 09 Challenger and 22 in the beat up 5 speed 1990 Ram 150 shop truck, {low 13 sec.] playing on wed nights.
19 Finals---12 wins--7 R/U--9 semis--12 1/4s
Beat up on a lot of Chevys and Fords this year!
I didn't get to many,, 15 in the coronet 12 in my duster
Dan you are the most noted toughest racer in the area,!
look forward to your words of wisdom for me this coming year !!
HAPPY NEW YEAR !!
Re: How Many Runs Did You Get In This Year? [Re: dennismopar73] #1362251
01/02/13 01:31 AM
01/02/13 01:31 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I would guess 75 or so...I was out 9 times. Only ran it all out 4 times...it needs an anti-roll big time Got my 8 sec slip and there is plenty more left. I will be running IHRA Div 1 S/R with a vengence this year for sure..
5.53 @ 125 1/8th on the launch control..more left in her!
Page 2 of 3 1 2 3
