Index racing
#1361508
12/30/12 02:37 PM
12/30/12 02:37 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
Anybody here index race? I'm going to try 6.00 and 7.00 1/8 mile no electronics in OKC/TX this year with 2 cars. First time- What should I look out for or be aware of? ![](/ubbthreads/images/graemlins/thumbs.gif)
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: Index racing
[Re: 65 Hemi]
#1361509
12/30/12 02:45 PM
12/30/12 02:45 PM
Posts: 4,993 new jersey usa
11secdart
new jersey usa
I`m going to try it this year also,11.50 index. I run Street Eliminator ( 11.50 -19.99) and can set the car to go consistent 11.50s but Street is on a full tree and 11.50 index is on a Pro tree. That will be the difference for me as I`ve always ran on a full tree. Racing two classes on the same day will be interesting.
Re: Index racing
[Re: 65 Hemi]
#1361514
12/30/12 03:43 PM
12/30/12 03:43 PM
Posts: 1,141 Phoenix,Az.
hemicop
Phoenix,Az.
Good Luck! As others have said, data & consistency is the key & when racing guys that are SERIOUS about it, that means you'll be racing what I call an "electronic car" --throttle stops, timers, ignition retards, active suspension, transbrakes, are all part of the "game" & for those of us that like running all out or seeing just how good a driver REALLY is the leectrics (IMO) take all the fun out of it. If it still appeals to you, plan on spending at least $1,500 on upgrades, less the data recorder......
Re: Index racing
[Re: hemicop]
#1361515
12/30/12 04:14 PM
12/30/12 04:14 PM
Posts: 2,690 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
All we really do around here is index race. The only problem is getting your car to run the number in the first place. I have a buddy with a car that will run 6.16 and he spent all year and $26,000 (rebuilt the motor twice and changed the converter 9 times) trying to get it to run 6.0. If he would have run the 6.50 class (we have one of those here) he would have had an easy (and inexpensive) year. But noooo, you know drag racers, they always want to go faster. 6.0 and 7.0 are popular. 6.0 takes a lot of power and eats parts. 7.0 is cheaper and easier to make hook up. Index racing is great and you are still set up for bracket racing if you want to do that.
2011 Drag Pak Challenger
Re: Index racing
[Re: rickseeman]
#1361516
12/30/12 04:28 PM
12/30/12 04:28 PM
hemicop
Phoenix,Az.
.......And that's the problem with index racing! For 26k he could've built a different car, or, as you said, simply slowed down & saved quite a few bucks. The problem, as I see it, is that any racer naturally wants to build the best stuff he can, then he has worry about SLOWING ![](/ubbthreads/images/graemlins/eeek.gif) the car down or he LOSES?!?! ![](/ubbthreads/images/graemlins/down.gif) ....... NO THANKS! I'll build my junk MY way then worry about who I "please" with it. Will I win trophies and/or money? Probably not. But I also won't get fingered for sandbagging, relying on electronics or penalized for for building a fast car..
Re: Index racing
[Re: hemicop]
#1361517
12/30/12 04:44 PM
12/30/12 04:44 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
You need to be able to run under your index to be competitive in all weather. I would slow my car down for 10.0 index, the best motor pass my car has made was 9.55. I like index racing because you get to leave together and race the whole track together. And be prepared for a lot of finish line games. Also throttle stops are not allowed around hear for index racing.
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: Index racing
[Re: 65 Hemi]
#1361519
12/30/12 05:33 PM
12/30/12 05:33 PM
Posts: 20,226 Park Forest, IL
slantzilla
Park Forest, IL
You guys do realize index racing is just a bracket race that someone picks your dial for you, right?
Re: Index racing
[Re: slantzilla]
#1361520
12/30/12 06:01 PM
12/30/12 06:01 PM
65 Hemi
San Diego CA
yes but you can't change your dial in or just just click a few #s in your E-box as the conditions change. It a little more fun when the driver needs to change or tuning needs to change with no E.
Re: Index racing
[Re: slantzilla]
#1361521
12/30/12 06:03 PM
12/30/12 06:03 PM
11secdart
new jersey usa
Same here chased E.T.s for years , now the car is slowed down about a second with a modified Moroso mechanical ( adjustable bolt) stop. Never had a problem dialing the car I can adjust for slower and faster with a 7/16 wrench. I looked at the E.T. Genie and the other one with a dial to adjust the plates but wasn`t sold on them. I have my setup pretty well set after 4 years/ seasons of running this way. My past 4 seasons have been the best in my racing career with more Wins and rounds won than the previous 20 plus.Being one of the fastest cars in the class does have its advantages. BTW I`m running the same car (11secdart) in both classes on the same day. Also no electronics are allowed except transbrake and/or two step.
Re: Index racing
[Re: slantzilla]
#1361524
12/30/12 07:27 PM
12/30/12 07:27 PM
Posts: 1,186 OHIO
THE GLASS MAN
OHIO
Heds up racing is what?
