Re: BATTERY CABLE QUESTION...............................
[Re: Dart1031]
#1360228
12/29/12 11:08 AM
12/29/12 11:08 AM
Posts: 9,897 MI, usa
dvw
MI, usa
Buy an 8lb. Lithium battery and put it back up front. You'll save 30lbs from the battery you have now and have 10 less feet of cable. Plus you can remove the cut off switch and save more weight.
Wise desicion
[Re: pittsburghracer]
#1360231
12/29/12 11:32 AM
12/29/12 11:32 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
Here is a wiring chart we use, if you know how many amps your starter pulls and how long the cable is here's your answer. We use 1 gauge on most everything. I second the lithium battery, cost more upfront but lightweight and compact. I like the Prolite Lithium batteries www.prolitebatteries.com ![](/ubbthreads/images/graemlins/Twocents.gif)
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: Crizila]
#1360235
12/29/12 12:39 PM
12/29/12 12:39 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
MSD says run 2 gauge welding cable. ![](/ubbthreads/images/graemlins/thumbs.gif) Also per MSD I run a #4 gauge welding cable from each head to the side of the block where I also run the MSD ground wire and from there run a #4 gauge cable to the neg- side of the battery! Solved a Hi-Speed miss for me a few years back.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: Thumperdart]
#1360237
12/29/12 12:54 PM
12/29/12 12:54 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Dom it' good to run to a insulated stud or bulkhead connector (like dvw showed) at the dash area and feed the rest of the car. That way you are not using the starter as a junction block.
I would use #1 from battery to block, then #2 to starter.
Have fun
"Just a Bracket car dressed up like a streetcar"
[Re: dvw]
#1360241
12/29/12 02:34 PM
12/29/12 02:34 PM
Posts: 4,213 New York
polyspheric
New York
Copper:aluminum = apples:oranges
Boffin Emeritus
