Re: 6bt Cummins in an abody?
[Re: SLOW67]
#1359775
12/27/12 02:58 PM
12/27/12 02:58 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Just found a nice running early 12v for a steal, What are your thoughts on a cummins fitment in an abody? Will it weigh more than a iron headed BB? Need a lift pump to the IP? Just throwing this out for discussion...
LOL... that engine weights about 900-1000 lbs... better get some new T-bars.... but if its in good shape and its a steal its worth picking it up(at least it is to me)
[Re: MR_P_BODY]
#1359777
12/27/12 03:01 PM
12/27/12 03:01 PM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
I've thought about this too but I think the 4BT would be a better fit.
[Re: SpareParts]
#1359779
12/27/12 04:57 PM
12/27/12 04:57 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
I could be wrong, but I think the radiator would have to mount where the front bumper would normally go to fit that monster in there.
[Re: bwdst6]
#1359781
12/27/12 05:25 PM
12/27/12 05:25 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
I feel sorry for the ball joints in there Also they are very tall and would require a 6 pack scoop stretched from the front of the hood to the cowl just to cover it all up. Plus to get the crank center-line correct you would have to shrink the oil pan or it will drag the ground or raise the trans tunnel from front to back a few inches or maybe a combination of both.
[Re: bwdst6]
#1359784
12/27/12 08:45 PM
12/27/12 08:45 PM
Posts: 2,119 sc
tjmarcus1
sc
I don’t get it, if you want to go cheap. Put a SBC in there!
When you say "sbc", you DO mean Small Block Chrysler, don't you?
[Re: tjmarcus1]
#1359785
12/27/12 09:16 PM
12/27/12 09:16 PM
Posts: 970 Backwater, PA
bwdst6
Bob George Racing #1 Fan
Backwater, PA
No, it's pretty well known how cheap a small block Chevy combo is!!!
This post is available in double vision where drunk.
[Re: SLOW67]
#1359787
12/27/12 11:00 PM
12/27/12 11:00 PM
Posts: 12,409 Taxes & Virus's R-US, NY
Dragula
You could buy my ProStreet '78 D100 and throw it in there. It fits, and I know it does. I thought about doing it a few times...THe 6-speed trans will help keep weight down a little.
