318 oil filter adapter, does it use a gasket? #1358775
12/25/12 01:38 AM
12/25/12 01:38 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I just started up a fresh 318 , it came with the project i got , and oil just gushed from the oil filter. It does not have the 90 degree adapter just the factory adapter/plate on the block. I pulled the filter and plate off and there was no gasket between the block and plate. so i am guessing thats the problem. Should there just be one large gasket or should there also be another smaller one where the threaded piece goes in that holds the.plate on?
Re: 318 oil filter adapter, does it use a gasket? [Re: dirt] #1358776
12/25/12 05:48 AM
12/25/12 05:48 AM
SE PA
Yellow Fever Offline
SE PA
Re: 318 oil filter adapter, does it use a gasket? [Re: Yellow Fever] #1358777
12/25/12 11:14 AM
12/25/12 11:14 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I dont use the angle adapter ,just the stock thin plate. Does it still use the same gaskets?
Re: 318 oil filter adapter, does it use a gasket? [Re: dirt] #1358778
12/25/12 11:50 AM
12/25/12 11:50 AM
Just the large ring gasket under the flat plate. No smaller gasket of any sort is used on either side of the threaded nipple. As noted the 2 smaller gaskets plus the ring gasket in the 3 piece kit are used in the 90 deg adapter only. Fel pro offers the large ring gasket seperately (#70078 iirc) & reportedly it is slightly thicker than the ring gasket that comes in the MP 3 piece gasket kit which is better & the single gasket would for sure be cheaper so call your parts house & see if they have one on hand. Do make sure the block circular recess & the plate are squeaky clean.
Re: 318 oil filter adapter, does it use a gasket? [Re: RapidRobert] #1358779
12/25/12 01:00 PM
12/25/12 01:00 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
Thanks, thats what i was trying to figure out. I wanted to get it right.
.its the only gasket i didnt think to check. Since i noticed no one put any gasket or sealer on the water pump either i thought i should go over it. Its my sons car and we have been working on it for a couple years. I wanted to get it fired up for christmas for him . It did start right up but we shut it off when i seen oil running out, but at least we know it runs.
Re: 318 oil filter adapter, does it use a gasket? [Re: dirt] #1358780
12/26/12 01:21 AM
12/26/12 01:21 AM
kansas city, mo
rave_12000 Offline
rave_12000  Offline
kansas city, mo
i made the same mistake with a 340 once. i prolly have one if you want it. mike 8167998844
Re: 318 oil filter adapter, does it use a gasket? [Re: rave_12000] #1358781
12/26/12 07:19 AM
12/26/12 07:19 AM
5thAve Offline
5thAve  Offline
you can get the gaskets individually from the dealer too.
Re: 318 oil filter adapter, does it use a gasket? [Re: 5thAve] #1358782
12/26/12 01:00 PM
12/26/12 01:00 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I ordered a gasket so now i should be all set.
Re: 318 oil filter adapter, does it use a gasket? [Re: dirt] #1358783
01/01/13 09:53 PM
01/01/13 09:53 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I got the fel pro gasket 70078 but it dosent fit. It is a rubber o ring , not quite big enough to fit. I think the original was not rubber either, i pulled one out of an old 360 to look at.
I still need the gasket and cant figure out what i need to order.
Re: 318 oil filter adapter, does it use a gasket? [Re: dirt] #1358784
01/01/13 10:49 PM
01/01/13 10:49 PM
I had no idea that # was not correct . I copied it down at the time but never had to order one
Re: 318 oil filter adapter, does it use a gasket? [Re: RapidRobert] #1358785
01/03/13 11:34 AM
01/03/13 11:34 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
Thats the same part number i found on napa's web site.
Here is the number i just got and it fits 70522. Its fel pro
Re: 318 oil filter adapter, does it use a gasket? [Re: dirt] #1358786
01/03/13 12:47 PM
01/03/13 12:47 PM
IMGTX Offline
IMGTX  Offline
Yes there is a gasket but a very important thing to do while you have the plate off is to add more holes.
It is very common for the 318's to have 4 small holes to let the oil flow from the filter to the block. 340's and 360's had 6 or 8.
either get a 340/360 plate or add some holes to the 318 plate. That is simply not enough oil flow. Your bearing will love you for it.
Re: 318 oil filter adapter, does it use a gasket? [Re: IMGTX] #1358787
01/03/13 01:05 PM
01/03/13 01:05 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I never knew there was a different part number for the plate. 2402103 was the only number I could find. Do you have a part number for the one with more holes? Now I have seen the billet aluminum ones with more holes but they were aftermarket.
Re: 318 oil filter adapter, does it use a gasket? [Re: dirt] #1358788
01/03/13 01:09 PM
01/03/13 01:09 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I have a kit for that, #340-K5
You won't find a better quality material than this.
Available from Competition Wedge or Marsh Performance/ Moparts Connection. I think Mancini plans to carry them sometime this year.
Send me a PM if nobody has them in stock.
Re: 318 oil filter adapter, does it use a gasket? [Re: roadhazard] #1358789
01/03/13 02:05 PM
01/03/13 02:05 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I chased an oil leak from that same part on a 360 that I built for a truck about 20 years ago. I was laying under the running truck when the leak became major and splashed onto my headers...I did not know that I could move so fast!!
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 318 oil filter adapter, does it use a gasket? [Re: mopars4ever] #1358790
01/03/13 05:50 PM
01/03/13 05:50 PM
IMGTX Offline
IMGTX  Offline
I do not have a part number with me but they used the same plates on the LA and Magnum small block. You an get one from a Junkyard 5.9 and use it or just drill a few extra holes. Here is a picture of a 318 vs 340/360 plate.
Re: 318 oil filter adapter, does it use a gasket? [Re: dirt] #1358791
01/03/13 10:53 PM
01/03/13 10:53 PM
Duly noted. Thank you!
Re: 318 oil filter adapter, does it use a gasket? [Re: RapidRobert] #1358792
01/03/13 11:51 PM
01/03/13 11:51 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I never noticed the 318 having less holes, i have an extra from a 360 i can use. I just put it back on today.
