Re: Scotty/Dustedu's 440 W9 rp
[Re: jim sciortino]
#1358675
02/25/13 07:40 PM
02/25/13 07:40 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
I've talked to Laverne at the NHRA div 2 finals before, I'm sure he doesn't remember me but his car is nice, very nice and hauls azz. Would love to see the numbers on this engine.
[Re: SB412DUSTER]
#1358677
02/26/13 12:02 PM
02/26/13 12:02 PM
Guitar Jones
I'm going to let Scotty decide if he wants the numbers from the dyno on here.
Guitar Jones, were you the guy that talked to me about my hood scoop at Valdosta?
No I was talking to you about your front end rack setup. It's been quite a few years.
[Re: SB412DUSTER]
#1358678
02/26/13 11:39 PM
02/26/13 11:39 PM
Posts: 993 Louisville, MS
Dustedu
Louisville, MS
I don't mind it made 1030@8400 & 718ftllbs @ 7100 This was best pull we managed to get before we ran outta fuel. We didn't have but one five gallon pail and it went quick warming engine and sealing rings. I believe it has more in it we didn't change much we moved timing down two degrees and it lost 15hp/ went up 1.5 from starting timing and it responded with 22hp but we were out of fuel by then. It was also on rich side, we didn't even get to try a jet change. I'm not 100% sure but I believe it has at least 1050 in it!
Thanks again Laverne for the small block of my Dreams! Also need to thank Curtis Boggs, Steve Lowe, John Beck and VDL fuel systems
[Re: SB412DUSTER]
#1358680
02/27/13 12:22 AM
02/27/13 12:22 AM
Posts: 84 Minnesota
Coldart
Minnesota
VERY IMPRESSIVE! Why would you build anything else? W9RP's are the only way to go!
[Re: Coldart]
#1358681
02/27/13 01:30 AM
02/27/13 01:30 AM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
care to share any more of the engine combo? killer #'s
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: SB412DUSTER]
#1358683
02/27/13 03:36 AM
02/27/13 03:36 AM
Stroker Scamp
pacific northwest
yup it was thanks, who again did the heads?
[Re: Dustedu]
#1358686
03/02/13 12:27 AM
03/02/13 12:27 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
wow that makes some steam. I will be happy if my w8 440 makes 800'es this gives me hope thanks
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: 340Cuda]
#1358690
03/02/13 11:51 AM
03/02/13 11:51 AM
Posts: 2,360 Mobile Alabama
SB412DUSTER
Mobile Alabama
Very impressive!
Are the exhaust ports in the same location on the W9 RP as the other W9 heads?
Bill
No..The bolt pattern is the same but the ports are 1/4 higher
[Re: SB412DUSTER]
#1358692
03/02/13 01:08 PM
03/02/13 01:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Might have been me when I meet you down there about a couple years ago
