I checked with the folks at AED, where the carb was purchased. They said to check the float levels first, then adjust the AF mixture screws in 1/8 turn at a time, and do this about a total of 2-3 times and then see if it remedies the problem. Would adjusting the AF mixture screws affect the car at movement even though they are on the idle circuit?....Thanks
