Steering Column Assembly and Maintenance. #1358492
12/24/12 03:48 PM
12/24/12 03:48 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
Hi all. So I'm painting up my last piece of the steering column and before I put it together I just want some input on what I should do. It's a floor shift power-steering column. I currently don't have any lube or grease on hand and was wondering if you guys had any input on what I should buy. Also, my ball bearing seem to be worn out a little. Let's just say they make some crunchy noises for a little when spun (less now). Should I order new bearings or just lube these guys up? Any tips or tricks before I get started putting it together would be greatly appreciated. I've got the 69 Service Manual on pdf and plan on following that for the reassembly. Thank you!
Re: Steering Column Assembly and Maintenance. [Re: MuuMuu101] #1358493
12/24/12 04:21 PM
12/24/12 04:21 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
'I've got the 69 Service Manual on pdf and plan on following that for the reassembly.'
There you go...
(If it was me, any bearings would get replaced)...
Re: Steering Column Assembly and Maintenance. [Re: RSNOMO] #1358494
12/24/12 04:29 PM
12/24/12 04:29 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
On a side note, your education is evident in your posts. Thank you for going to college and sparing us the pain of sifting through messy habits that others perpetrate against the English language!
Re: Steering Column Assembly and Maintenance. [Re: MuuMuu101] #1358495
12/24/12 04:41 PM
12/24/12 04:41 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
If it was me, I'd get the new bearing(s). Can't remember if that year had a lower or not.
The joy of getting it all together will be outweighed by the reminder of the semi-crunchiness of the upper bearing every time you drive it...
(A paraphrase of the original: "The joy of a great price will be outweighed by the disappointment of poor quality" or some such.)
Re: Steering Column Assembly and Maintenance. [Re: MoparMarq] #1358496
12/24/12 04:46 PM
12/24/12 04:46 PM
SoCal
SoCal
Anyone know what size or where to buy bearing? Our shop uses McMaster Carr for most our purchases, but I was wondering if other options were available.
Re: Steering Column Assembly and Maintenance. [Re: Kern Dog] #1358497
12/24/12 05:03 PM
12/24/12 05:03 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
LMAO...
Yes, the power of the correctly spelled werd knows no bounds...
(Detroit Ball Bearing, and Bearing Service are the choices in these parts...
What 'chu gonna do with that 'custom' steering coupler???)
Re: Steering Column Assembly and Maintenance. [Re: Kern Dog] #1358498
12/24/12 05:07 PM
12/24/12 05:07 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
wacha be trin to say? U and i needs to be conversatin bout this here. i tak afence to it! (seriously, i too applaud MuuMuu!)
Re: Steering Column Assembly and Maintenance. [Re: RSNOMO] #1358499
12/24/12 05:10 PM
12/24/12 05:10 PM
SoCal
SoCal
LMAO...
Replace it completely...
This is most the parts repainted about 2-3 weeks ago.
Since then, I've touched some of them up and I just sprayed the steering wheel hub. I really wish I hung the parts when I painted them instead of spraying them on cardboard. The cardboard ripped some of the paint off when removing them. I resprayed them a bit to fix them, but they're still not perfect. O well, they look good enough for me.
Re: Steering Column Assembly and Maintenance. [Re: MuuMuu101] #1358500
12/24/12 05:33 PM
12/24/12 05:33 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I'd repaint them, and hang them up this time...no point in saying 'oh well' since it's not something you will not be doing again to "fix" and it'll bug you every time you look at the spots where the paint is not nice too...
At least it would bug me.
(I've got a few old wire coat hangers I have stretched out and use to hang parts while painting, works great ! )
(and I have been painting stuff for the sway bar install lately. )
Re: Steering Column Assembly and Maintenance. [Re: OzHemi] #1358501
12/24/12 07:40 PM
12/24/12 07:40 PM
SoCal
SoCal
Thanks for jinxing my parts Oz! I swear they were perfectly fine before you made that comment and once I went back to check on them 3 parts that have already been finished had cardboard paint peal. I just touched up those parts now. Most of the places where the peal is located is hidden or under the dash so I don't mind too much. Next time I repaint something, though, they will be hung.
Re: Steering Column Assembly and Maintenance. [Re: MuuMuu101] #1358502
12/24/12 07:40 PM
12/24/12 07:40 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
LMAO...
Whatever you do, save that 'OEM' coupler...
That's one fer the books...
Re: Steering Column Assembly and Maintenance. [Re: RSNOMO] #1358503
12/24/12 07:46 PM
12/24/12 07:46 PM
SoCal
SoCal
That whole shaft/coupler setup is sitting comfortably on top of my shelf. That thing isn't going anywhere. I call it the "War-Hammer" primarily because it's large, a little heavy, and the only purpose it serves (now) is a good object to wack people with.
Re: Steering Column Assembly and Maintenance. [Re: RSNOMO] #1358504
12/24/12 08:40 PM
12/24/12 08:40 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
It is even more impressive in person..
Re: Steering Column Assembly and Maintenance. [Re: OzHemi] #1358505
12/24/12 09:13 PM
12/24/12 09:13 PM
SoCal
SoCal
Next time I bring it to the cruise, I'll bring it so you can really take a look at it.
Re: Steering Column Assembly and Maintenance. [Re: MuuMuu101] #1358506
12/26/12 01:30 AM
12/26/12 01:30 AM
kansas city, mo
rave_12000 Offline
rave_12000  Offline
kansas city, mo
you could become the "thor" of steering columns. lol.
any grease should work...just as long as it is greasy. i have always had a bunch of columns laying around. unless the bearing is completely apart...i grease and throw back together. needle tip for the grease gun is sometimes helpful to hit tight spots.
Re: Steering Column Assembly and Maintenance. [Re: rave_12000] #1358507
12/26/12 02:40 AM
12/26/12 02:40 AM
SoCal
SoCal
I need to start getting a Moparts Superhero outfit together.
Re: Steering Column Assembly and Maintenance. [Re: MuuMuu101] #1358508
12/26/12 01:13 PM
12/26/12 01:13 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You better not be using those shiny new tools to half-ass the car.
Hang 'em up and paint 'em right. Replace that crunchy bearing too.
- Stu Harmon
Re: Steering Column Assembly and Maintenance. [Re: feets] #1358509
12/26/12 03:13 PM
12/26/12 03:13 PM
SoCal
SoCal
I don't paint with ratchets and wrenches? I'll probably end up redoing them anyways. I need to pull some hangers from my closet. And does anyone know the bearing sizes?
Re: Steering Column Assembly and Maintenance. [Re: MuuMuu101] #1358510
12/27/12 05:31 PM
12/27/12 05:31 PM
Utah
E
Eagleone1983 Offline
E
Utah
Sorry don't have a bearing size for ya but the lower bearing is remanufactured and is availible at most of the Mopar parts dealers. Luckily both my bearings were good and just needed some repacking.
