Re: 1971 GTX vibration issue [Re: AfterHoursResto] #1358292
12/26/12 07:08 PM
12/26/12 07:08 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
I had the same problem. You may want to have the driveshaft re-checked. I had 2 new d-shafts from local d-shaft companies. Both fresh and "balanced".
Guess what...? They weren't...
Re: 1971 GTX vibration issue [Re: 318 Stroker] #1358293
12/29/12 12:06 AM
12/29/12 12:06 AM
MI
AfterHoursResto Offline OP
MI
Thanks for all the suggestions and pictures. I had to step away from this issue because of the holidays but will get back on it tomorrow. I will keep you posted with what I come up with! Thanks.
Roman Sobilo
Re: 1971 GTX vibration issue [Re: 318 Stroker] #1358294
12/29/12 08:34 AM
12/29/12 08:34 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
They can't spin them fast enough, I ran into this as well. Most truck shops only spin 2000-2500 rpm since the big diesels don't go any higher than that. Their eyes just about popped out of their head when I informed them that would not even cover my cruise speed and driveshaft revolutions over 6000 rpm were common.
Re: 1971 GTX vibration issue [Re: gdonovan] #1358295
12/29/12 06:34 PM
12/29/12 06:34 PM
NJ
rth Offline
rth  Offline
NJ
There is a difference between eng rpm's and d/shaft revolutions. d/s is measured by mph. 2500 rpm's could be 60 mph depending on gears and tire size.
Re: 1971 GTX vibration issue [Re: rth] #1358296
02/10/13 10:28 PM
02/10/13 10:28 PM
MI
MI
Hey Guys, I shelved this issue for a while but finally got back to it. So the issue was the big ball bearing that rides on the output shaft in the tail shaft housing. I did get lucky as far as it being an easy fix. It really sucks to tear apart a freshly restored restoration.
Thanks for all the suggestions and pictures. The vibration is gone!
Roman
Roman Sobilo
