Re: rod side clearance,proper torquing,pinion angle,which , [Re: gregsdart] #1357549
12/23/12 04:39 PM
12/23/12 04:39 PM
Regina Sask, Canada
V
Viper469 Offline
Viper469  Offline
V
Regina Sask, Canada
I,ve got a stock 400 block with 906 heads. I wanted to upgrade and was wondering if i should go with the 600-13 or predator heads? which ones flow better. Would it be o.k to use the stock block if i used hardblock and a main girdle?
Re: rod side clearance,proper torquing,pinion angle,which , [Re: Viper469] #1357550
12/23/12 06:33 PM
12/23/12 06:33 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
What are the best inexpensive rockers?
Or for that matter,....What is the best, cheap ___________ ?(you fill in the blank)
Re: rod side clearance,proper torquing,pinion angle,which , [Re: BSB67] #1357551
12/23/12 07:22 PM
12/23/12 07:22 PM
Who knows the most about everything And who is bored the worst
Re: rod side clearance,proper torquing,pinion angle,which , [Re: Cab_Burge] #1357552
12/23/12 09:05 PM
12/23/12 09:05 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
.....and WHO can put the most and ... in each and every POST !
Re: rod side clearance,proper torquing,pinion angle,which , [Re: dOc !] #1357553
12/23/12 09:47 PM
12/23/12 09:47 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Should I run a windage tray?
I've installed a cam that's too big and my idle mixture screws don't change the idle even with 5 degrees of initial timing...it also dies/drops 1,000rpm when put into gear...What's wrong with my carb, it used to run great on the stock motor???
How much ET will I gain by going from 3.55's to 3.91's??
Are spark plug wires worth any horsepower?? Should I run Castrol Syntec, Splitfire plugs and Rhoads lifters??
I want a cam with a lot of "lope," which one should I run?
There are guys in the 7's on Drag Radials but my 12 second car won't hook with them even with Super Stock springs and a pinion snubber....
My car won't get into the 8's but I KNOW it's not down on power....what else could it be and if I don't like your answers I'll delete all my posts....(and BTW, I'll spend years and thousands of dollars trying everything and anything to prove the motor has plenty of power....)
How much is too much timing?
I own the greatest nitrous Mopar street car in the world and I tune it myself but if someone suggests I change my tuneup I do and burn my crap up....Would you guys please donate to me so I can afford to go on Dragweek again and make you proud to know me??
If you can't handle the truth, you're living a lie.......
Re: rod side clearance,proper torquing,pinion angle,which , [Re: Big Squeeze] #1357554
12/23/12 10:07 PM
12/23/12 10:07 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
How often should I change my blinker fluid?
Re: rod side clearance,proper torquing,pinion angle,which , [Re: bobs66440] #1357555
12/23/12 10:33 PM
12/23/12 10:33 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
blah blah experts blah blah
Re: rod side clearance,proper torquing,pinion angle,which , [Re: FastmOp] #1357556
12/23/12 10:49 PM
12/23/12 10:49 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Re: rod side clearance,proper torquing,pinion angle,which , [Re: MR_P_BODY] #1357557
12/23/12 11:03 PM
12/23/12 11:03 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
HI MR P BODY AND EVERY BODY 1/4, 1/2, 3/4, FULL, FILL ON MY 273 WHAT IS BETTER A HEMI OR WEDGE BECASUE I WANT A LS1 IN MY CAR.. WILL A BBC HELP ME MEET MY GOAL.. HOW MANY RPM CAN A 8 3\4 HANDLE CHINESE PARTS ARE THE BEST BECAUSE THEY HAVE MORE RICE AND KILL MORE JOBS WITH ALL THE CHINESE CRANKS AND RODS AROUND HERE WE SHOULD BE ABLE TO RACE AT THE IMPORT RACES
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: rod side clearance,proper torquing,pinion angle,which , [Re: WHITEDART] #1357558
12/23/12 11:10 PM
12/23/12 11:10 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
OH YEAH ALMOST FORGOT INDY SUCKS
Re: rod side clearance,proper torquing,pinion angle,which , [Re: WHITEDART] #1357559
12/23/12 11:27 PM
12/23/12 11:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Ok I will ask why you call me out by name? and
turn off your CAPS
Re: rod side clearance,proper torquing,pinion angle,which , [Re: MR_P_BODY] #1357560
12/23/12 11:52 PM
12/23/12 11:52 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
turn off your CAPS
BECAUSE I BET MY SON 20 BUCK IF I USED CAPS YOU WOULD SAY TURN OF YOUR CAPS MR.P I REALLY INJOY ALL YOU HELP FULL KNOWLAEDGE
Re: rod side clearance,proper torquing,pinion angle,which , [Re: WHITEDART] #1357561
12/24/12 12:24 AM
12/24/12 12:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
turn off your CAPS
Well I guess you won 20.... but they are so annoying
and makes it hard to read
Re: rod side clearance,proper torquing,pinion angle,which , [Re: gregsdart] #1357562
12/24/12 01:39 AM
12/24/12 01:39 AM
New York
polyspheric Offline
polyspheric  Offline
New York
My special hatred is reserved for those who know just enough to detail a very specific and expensive build, and need some predictions.
After wasting everyone's time (not mine, because my gay-dar is excellent on these squids) they thank everyone, and post a completely different question.
After a few repetitions it dawns on the remaining participants that the OP:
1. is 15
2. lives in his Mom's basement
3. has no car
4. or money
5. but likes to be taken seriously - which is something he couldn't possibly do in person
Boffin Emeritus
