Re: rod side clearance,proper torquing,pinion angle,which ,
[Re: Viper469]
#1357550
12/23/12 06:33 PM
12/23/12 06:33 PM
Posts: 4,324 Prospect, PA
BSB67
Prospect, PA
What are the best inexpensive rockers?
Or for that matter,....What is the best, cheap ___________ ?(you fill in the blank)
[Re: dOc !]
#1357553
12/23/12 09:47 PM
12/23/12 09:47 PM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
Should I run a windage tray?
I've installed a cam that's too big and my idle mixture screws don't change the idle even with 5 degrees of initial timing...it also dies/drops 1,000rpm when put into gear...What's wrong with my carb, it used to run great on the stock motor???
How much ET will I gain by going from 3.55's to 3.91's??
Are spark plug wires worth any horsepower?? Should I run Castrol Syntec, Splitfire plugs and Rhoads lifters??
I want a cam with a lot of "lope," which one should I run?
There are guys in the 7's on Drag Radials but my 12 second car won't hook with them even with Super Stock springs and a pinion snubber....
My car won't get into the 8's but I KNOW it's not down on power....what else could it be and if I don't like your answers I'll delete all my posts....(and BTW, I'll spend years and thousands of dollars trying everything and anything to prove the motor has plenty of power....)
How much is too much timing?
I own the greatest nitrous Mopar street car in the world and I tune it myself but if someone suggests I change my tuneup I do and burn my crap up....Would you guys please donate to me so I can afford to go on Dragweek again and make you proud to know me??
If you can't handle the truth, you're living a lie.......
[Re: MR_P_BODY]
#1357557
12/23/12 11:03 PM
12/23/12 11:03 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
HI MR P BODY AND EVERY BODY 1/4, 1/2, 3/4, FULL, FILL ON MY 273 WHAT IS BETTER A HEMI OR WEDGE BECASUE I WANT A LS1 IN MY CAR.. WILL A BBC HELP ME MEET MY GOAL.. HOW MANY RPM CAN A 8 3\4 HANDLE CHINESE PARTS ARE THE BEST BECAUSE THEY HAVE MORE RICE AND KILL MORE JOBS WITH ALL THE CHINESE CRANKS AND RODS AROUND HERE WE SHOULD BE ABLE TO RACE AT THE IMPORT RACES
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#1357558
12/23/12 11:10 PM
12/23/12 11:10 PM
WHITEDART
bean town ....Ca
OH YEAH ALMOST FORGOT INDY SUCKS
[Re: WHITEDART]
#1357559
12/23/12 11:27 PM
12/23/12 11:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Ok I will ask why you call me out by name? and turn off your CAPS
[Re: WHITEDART]
#1357561
12/24/12 12:24 AM
12/24/12 12:24 AM
MR_P_BODY
BQuote:
BECAUSE I BET MY SON 20 BUCK IF I USED CAPS YOU WOULD SAY TURN OF YOUR CAPS MR.P I REALLY INJOY ALL YOU HELP FULL KNOWLAEDGE
Well I guess you won 20.... but they are so annoying and makes it hard to read
[Re: gregsdart]
#1357562
12/24/12 01:39 AM
12/24/12 01:39 AM
Posts: 4,213 New York
polyspheric
New York
My special hatred is reserved for those who know just enough to detail a very specific and expensive build, and need some predictions. After wasting everyone's time (not mine, because my gay-dar is excellent on these squids) they thank everyone, and post a completely different question.
After a few repetitions it dawns on the remaining participants that the OP: 1. is 15 2. lives in his Mom's basement 3. has no car 4. or money 5. but likes to be taken seriously - which is something he couldn't possibly do in person
Boffin Emeritus
