Re: 17" or 18" wheel package for 71 Challenger? Opinions?
[Re: Mopar Mitch]
#1357475
04/03/13 07:29 PM
04/03/13 07:29 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
With all the talk of going to larger diameter rims, one single main reason why such larger rim diameters have ever existed, as well as introduced into the industry, is only to allow for larger diameter brakes. Just changing to larger diameter rims without other valid reasons, becomes a questionable act. So... its something to consider with the expense involved, not just to follow a fashion trend that some hobbiests are doing.
not exactly. shorter sidewall tires will have less "roll" under hard cornering, and can improve a cars handling.
I'd say its a function of 3 main things... style, bigger brakes, better handling.
**Photobucket sucks**
[Re: 70Cuda383]
#1357476
04/03/13 07:34 PM
04/03/13 07:34 PM
70Cuda383
Marysville, O-H-I-O
If you guys like taller tires, Federal makes some nice tires in 17" a lot of the Dakota guys use them on the stock 17x9 rims, and they're CHEAP! 255/55/17 around $100 a tire.
[Re: 70Cuda383]
#1357478
04/08/13 03:58 PM
04/08/13 03:58 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Sidewalls have become stiffer on newer tires over the past ~10+ years regardless of their sidewall heights. Profiles of 60-65-70 are still very common for new vehicles. Overall tire diameter is also a factor as determined by the car designers. It all becomes a "package" that is offered to state the character of a specific vehicle.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: RylisPro]
#1357481
08/08/13 04:36 PM
08/08/13 04:36 PM
Posts: 27,485 So Cal
autoxcuda
So Cal
I am going to get 18's all around as well. I would rather have 17's but I can't find a wheel company that makes a one-piece forged wheel in 17's only 18's. There seems to be as wide a variety of extreme summer tires in both sizes. Ideally I would want the same size wheel and tire at all four corners for tire rotations, but with the differences in back space on each car, you have to get the measurements exactly right. Might be just easier to go staggered. Having 17's in front just saves in cost of tire. 18's allow a 6 piston big brake kit
Why do you need a one piece forged wheel?
You can fit 6 piston brakes in 17" rims. It will have a 13" max rotor instead of a 14" max rotor.
[Re: autoxcuda]
#1357482
08/08/13 05:03 PM
08/08/13 05:03 PM
Posts: 2,432 NorCal
RylisPro
NorCal
One-piece forged for rigidity and strength Been proven in lap times the more rigid a wheel along with as wide a front wheel as possible translates to consistent faster times. Also I like the simplicity of a one-piece over a 3-piece. Forged wheels can take more abuse & are harder to damage Your right, I forgot about the 13" 6 piston
[Re: RylisPro]
#1357484
08/08/13 07:52 PM
08/08/13 07:52 PM
Mopar Mitch
If you really want to be serious about rim choices and lap times, consider the lightest rims intended for road racing and which are DOT approved.... check out ads in SCCA Sports Car magazine, etc.. and be prepared to pay fairly big $$$. Also, consider tire selections.. tread wear ratings, such as 200, are common for various clubs these days.. look at the new BFG "Rival" tires... for an 18"er... I'd consider 275-35-18 tires (200 tread wear) mounted on 18x10 rims front and rear (with about 5-5.5" backspace... 5.5 will keep it factory centered at 10" rim width)... tuck in your fender lips... and enjoy the laps to their fullest! But.. beware of street/hwy pot-holes as the short sidewalls on the tires may welcome dented rims, as well as some increase in street ride harshness (not so much on the hwy)... just determine a reasonable tire psi for street/hwy... and increase as needed (at least ~5psi~10psi) for track lapping sessions. There's not too many 17s offering decent sizes at 200 tread wear, sorry to say forget 16s (I have 16x10 rims, forged aluminum 2-pc road race rims, and have used them exclusively with Hoosier A6 275-45-16 having 40 tread wear for autocross competition).
Mopar Mitch
[Re: Mass_Mopar]
#1357485
08/09/13 09:44 AM
08/09/13 09:44 AM
Posts: 813 Ontario,Canada
brads70
Ontario,Canada
Have you got a picture from the side of your Charger? Just wondering what it looks like from that angle?
The garage primer spray job showing it's lines... ]
Sorry for the weird angle shots... not finding any dead-on sideways ones
Thanks!
