Re: 17" or 18" wheel package for 71 Challenger? Opinions?
[Re: BrianShaughnessy]
#1357442
01/01/13 07:07 PM
01/01/13 07:07 PM
Posts: 1,443 NW Chicago suburban area
Mopar Mitch
With all the talk of going to larger diameter rims, one single main reason why such larger rim diameters have ever existed, as well as introduced into the industry, is only to allow for larger diameter brakes. Just changing to larger diameter rims without other valid reasons, becomes a questionable act. So... its something to consider with the expense involved, not just to follow a fashion trend that some hobbiests are doing.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: beatgoeson]
#1357446
01/01/13 08:51 PM
01/01/13 08:51 PM
Posts: 802 central CT
cudazappa
central CT
In general you want 0 offset. on an 8" rim that's 4.5" Backspace, on a 9" that's 5".
On my Challenger, with 275/40 17s on 17x9s the fronts are a very tight fit. 5.25" backspace would probably be just the ticket. I just ran more negative camber instead of buying new rims. I have no issues whatsoever with 17x8s and 245/45s.
1971 Challenger
[Re: beatgoeson]
#1357447
01/01/13 10:44 PM
01/01/13 10:44 PM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
Can ask what back spacing are you guys are using front and back on a typical E or B-body when when using a 17/18" wheel? factory leaf spring locations.
on my charger i run FRONT:17x8,, 4.5" backspace, 245/45 tire REAR:18x9.5, 5.5" backspace, 295/45 tire
front all stock suspension, a body discs w/ 11.75" rotors rear hotchkis springs, stock location. i had a little rubbing in the rear due to 2nd gen chargers having this odd rectangular "thing" in the outer wheelhouse. i got rid of it by cutting that small area and putting in a small sheetmetal patch. probably wouldnt have had a problem if i went 275wide and/ or 40 series sidewall
if i had gone with custom wheels id have liked 4.25" backspace on my 8" fronts and 5.25" on my 9.5" rears to push both rims towards the wheel lips just a hair more. i may try a 1/4" spacer all around just for and
[Re: patrick]
#1357450
01/02/13 04:47 PM
01/02/13 04:47 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Always measure TWICE before pulling the trigger on wheels!
Mopar to the bone!!!
[Re: 72Swinger]
#1357451
01/02/13 07:56 PM
01/02/13 07:56 PM
Pool Fixer
Coram, NY
in these sizes, even budget oriented wheels are going to set you back 800-1000 bucks. for 70 odd dollars, this tool would be worth it
wheelrite
[Re: MuuMuu101]
#1357452
01/08/13 06:46 AM
01/08/13 06:46 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
Hey feets, or anyone? Aren't Nitto tires known to be a little smaller (dimension wise) compared to the other brand's equal-sized counter parts? I've only heard good things about the NT555, but I recall reading that in some of the reviews I've seen.
Yes. They are smaller than other brands in the same size. Noticeably. Too bad, i hear a lot ov good things about them. If you dont need ridiculously wide tires though (315's, 335's) then just get the measurements you need, and find the Nitto tires you want in that size, regardless ov the numbers on the side. Ie: if you want a 275/40/17 tire, buy a 295/40/17 Nitto (just an example, i haven't measured either size). And dont go by the website spec either... find some you can take a tape-measure to.
[Re: Black_Bee]
#1357454
01/22/13 03:26 PM
01/22/13 03:26 PM
Posts: 5,867 MA
Mass_Mopar
MA
I run 17/18s on my '69 Bee:
17x8 4.75" BS 18x10 5.5" BS
Unlike others on here, I had a heck of a time finding tires that were wide and tall enough for the rear. I ended up going with a Falken Azenis 295/40/18 on the rear. Side by side with my old 275/16/15s, the new tires are actually a hair taller (and wider of course). In hindsight, I should have just gone with the Nitto 295/45/18s and saved a bundle of $$$, but wanted something super agressive.
I also went with 17s/18s on my Charger. Personally I think 17/18 looks the best on B-bodies at least, the 17" wheel in the rear looks too small.
I bought forged aluminum Centerline Softtails and Nitto NT555 rubber
The Centerline wheels are made in America, light enough for me, and great looking
Front: 17x7", 4"BS 235/45/ZR17 Rear: 18x9.5", 5"BS 295/45/ZR18
If I did it again I'd definitely go wider up front, probably a 17x8 or 18x8" rim and a 255 or 275 tire.
