Page 2 of 3 1 2 3
Re: header kit or parts [Re: Clanton] #1356929
12/24/12 03:50 AM
12/24/12 03:50 AM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
Depends on how much you want to spend and how nice you want it to look. I bought a header kit from Jegs and a few extra j bends from summit. You can also buy weld rings so the welds don't protude into the tube when you butt weld. When i decided I needed two tube around the frame I bought cheap slip on collectors from summit. I used steel tubes and mig welded them. Looks like crap on the outside, looks fine on the inside.
https://board.moparts.org/ubbthreads/show...rue#Post7358657
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: header kit or parts [Re: earthmover] #1356930
12/24/12 01:37 PM
12/24/12 01:37 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
2 step style
1st pri dia... 2.050" ... length .. 16.7" to 18.3"
2nd pri dia... 2.175" ... length .. 16.7" to 18.3" coll. size 3.725" to 3.975" .. length 17.9"
this is the header I plan to build for my race car .. what are you guys doing for the bends and flanges??? buying kits and make them work how you like or just buy a lot of diff. bends and so on???who has the best price on this kinda stuff??? I have seen where guys buy big block chevy kits and use them with the mopar flange cut weld cut weld..lol
I wonder how well those sizes will fit togather,I have a pipe expander that I may use to make some slip joints.Have A very Merry Christmas ALL of you!
Re: header kit or parts [Re: Clanton] #1356931
12/24/12 04:06 PM
12/24/12 04:06 PM
nc
E
earthmover Offline OP
E
nc
i havde been thinking about that myself... just a good slip fit would be great but a 1/4 is kinda big in this case...I am going to take a look at the other size.. I think they are just a little longer .. will post back on the other size as well..
Re: header kit or parts [Re: earthmover] #1356932
12/24/12 04:39 PM
12/24/12 04:39 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
It should all slip together. I always purge the tubes also, best way to get a good looking and strong weld on the tubes.
One day I will have something cool here.
Re: header kit or parts [Re: sdaurity] #1356933
12/24/12 04:59 PM
12/24/12 04:59 PM
Hot Rod Ridge
FastmOp Online tonguue
FastmOp  Online Tonguue
Hot Rod Ridge
I like the headman flanges with stubs. I used edelbrock slip on merge collectors and a box of bends from headman also. This is my second set of headers built and really like the results.
Re: header kit or parts [Re: FastmOp] #1356934
12/24/12 05:23 PM
12/24/12 05:23 PM
nc
E
E
nc
man that's a great looking set of headers
Re: header kit or parts [Re: earthmover] #1356935
12/24/12 10:05 PM
12/24/12 10:05 PM
nc
E
E
nc
single primary style header
pri dia... 2.050" to 2.175" ...length 33.5" to 36.6"
collector dia... 3.725" to 3.975" .. length 17.9"
2 step style
same collector
3 step style
1st pri dia... 2.050" ... length ..16.7" to 18.3"
2nd pri dia... 2.175" ... length ..8.4" to 9.1"
3rd pri dia... 2.300" ... length .. 8.4" to 9.1"
same collector but stay to the large size
all specs are OD with a wall thickness of .062
this is what the program came up with ,and my choices to go by...I was thinking the step would make the most power..and I need all I can get..lol
Re: header kit or parts [Re: earthmover] #1356936
12/24/12 11:02 PM
12/24/12 11:02 PM
Hot Rod Ridge
Hot Rod Ridge
It's all up to the amount of room you have. That's the main factor
My car being stock with T bars and stuff it's all a trade off. I just went big and unequal lengths. 2&1/4 with short and longs lol. It's hard get the fronts short with stock shocktowers.
These were what put my car in the fives in the 1/8. I had hooker fenderwell supercomps and it would run hi O's. Only thing changed were headers and it went low .90's
Re: header kit or parts [Re: FastmOp] #1356937
12/24/12 11:12 PM
12/24/12 11:12 PM
nc
E
E
nc
they will be on a chassis car with strut frontend..only thing really there is the master cylinder and brake stuff is mounted in the floor...ill take some good shots of the front and the room I have .. the pass. side is open just the driver has the normal.....
Re: header kit or parts [Re: FastmOp] #1356938
12/25/12 12:49 AM
12/25/12 12:49 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
this is what I have,stock fenders,shock towers Tbars so I only hope to cut the fender to allow the headers[6"x8" hole]I wish you had a pic of them on the car.
Re: header kit or parts [Re: Clanton] #1356939
12/25/12 01:40 AM
12/25/12 01:40 AM
Hot Rod Ridge
Hot Rod Ridge
Here's the only pick I have with them on the car.
Re: header kit or parts [Re: FastmOp] #1356940
12/25/12 02:18 AM
12/25/12 02:18 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
AWSOME,Thanks!
Re: header kit or parts [Re: DusterDave] #1356941
12/25/12 03:28 AM
12/25/12 03:28 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Since we're talking about building headers, where can I get that star shaped filler piece that fills in the space between the primary pipes before the collector is put on? I don't know what that piece is called, so its hard to find it online.
The "merge collector"? or just the piece with the 4 holes in it that is filler?
Re: header kit or parts [Re: earthmover] #1356942
12/25/12 04:10 AM
12/25/12 04:10 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Get a Hedman BB MoPar kit or SBC kit and flanges from anybody for the least expensive option.
Step headers require a little more thought , but you have enough room to do anything you want header wise.
Re: header kit or parts [Re: tubtar] #1356943
12/25/12 06:21 PM
12/25/12 06:21 PM
nc
E
E
nc
here are a few up to date pics with the room I have to work with
bigmike540/http://i1123.photobucket.com/albums/l548/bigmike540/2012-12-25_12-20-40_538.jpg2012-12-25_13-47-43_671.jpg]http://i1123.photobucket.com/albums/l548...3-47-43_671.jpg[/url]
http://i1123.photobucket.com/albums/l548/bigmike540/2012-12-25_12-21-17_389.jpg
http://i1123.photobucket.com/albums/l548/bigmike540/2012-12-25_12-20-26_126.jpg
http://i1123.photobucket.com/albums/l548/bigmike540/2012-12-25_12-20-09_587.jpg
so that's where I am at as of right now...trying to make all the progress I can before the 2nd when I go back out of town to work..
Re: header kit or parts [Re: earthmover] #1356944
12/25/12 08:02 PM
12/25/12 08:02 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Don't even waste your time trying to go inside the frame rails....they are most likely narrower than the stock rails.
Outside them , and back for tire clearance.
You'll have beaucoup room.
Re: header kit or parts [Re: tubtar] #1356945
12/25/12 10:44 PM
12/25/12 10:44 PM
Hot Rod Ridge
Hot Rod Ridge
Looks like u have it easy
Re: header kit or parts [Re: tubtar] #1356946
12/25/12 11:36 PM
12/25/12 11:36 PM
nc
E
E
nc
only thing with going to the outside of the frame rails is on the driver side the master is right there and may get to hot...I know I can fab a shield so that may just be the way to go...I know on some car they get really close on the fire wall and the shield works well so I will take a good look at it..so now who has the best price on flanges with the stub on them?????if I had a lot more time I would try and make my own out of just the flange itself but most of the time I only have 1 days home to work on the car ....
Re: header kit or parts [Re: earthmover] #1356947
12/25/12 11:58 PM
12/25/12 11:58 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I think you will be ok on the MC,if mine dont overheat you should be good with an open fender.
Re: header kit or parts [Re: Clanton] #1356948
12/26/12 12:11 AM
12/26/12 12:11 AM
nc
E
E
nc
good to here from those that have done it
Page 2 of 3 1 2 3
