Re: How to get 10.90s pump gas 440 in a 'cuda [Re: cudadoug] #1354765
12/18/12 04:34 PM
12/18/12 04:34 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
My '70 'Cuda went 11.20's at LACR on pump,had a 440,10.5 compression,.055 over,Indy SR heads ported,Indy single plane intake,950HP carb,a Indy spec .601/.608 solid flat tappet cam,8" convertor,but was pretty tight,{slow 60ft showed it},4.56 gears,28" Mickeys,full length exhaust with 'Cuda tips,3" Flowmaster 30series muffs,track is about 3500ft elevation,Bakersfield{closer to sea level} is good for at least tenths on most cars.My car is 3780 with me in it,I dropped exhaust out of car once and went 11.08 at LACR.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: johnnycuda] #1354766
12/18/12 06:11 PM
12/18/12 06:11 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I must say I have always liked the .590 cam. I had a cam speced for my eng and its close to the .590 specs as my lift is .588 and .592 but I use 1.6 rockers to make it .628 and .632. I have seen some good running combo's with the .590. Ron
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: 383man] #1354767
12/18/12 11:57 PM
12/18/12 11:57 PM
junction city oregon
V
viperblue72 Offline OP
V
Thanks guys. I may still try the stock stroke. I assume 6500+ rpm combination? If so are oiling mods necessary to the 440? I do plan to run a deep pan and high volume pump.
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: viperblue72] #1354768
12/19/12 12:11 AM
12/19/12 12:11 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
My old combination in my Challenger ran for a lot of seasons with just a Milodon pan and hv pump,3/8 pickup.
440, stock forged crank home ported 915 heads,590 cam flat top Pro Tru pistons,10 to 1.
Pump gas,10.90 in the heat @ 3325 lbs.
J converter 4.56 gear,32" tire.
Keith
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: Dunnuck Racing] #1354769
12/19/12 10:47 AM
12/19/12 10:47 AM
gregsdart Online content
gregsdart  Online Content
Forgot to mention my friends that run that combo shift at 6000 or 6200! Single plane, old style 850 4781, 2 1/8 Supercomp hookers.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: gregsdart] #1354770
12/19/12 01:09 PM
12/19/12 01:09 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I haven't run a bunch of different BB combos, so this is from a keyboard commando!
All things being equal, I'd prefer running more cubes at lower RPM than small (stock) cubes at a higher RPM.
Air and fuel volume will be equal, so you will need a good upper end either way.
Converter will be required either way, and more torque will be nicer on the street than a peaky high HP/RPM motor that is soft down low.
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: viperblue72] #1354771
12/19/12 01:29 PM
12/19/12 01:29 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Yeah, it can done:
A. Original combination that went 10.9s - 11.0s (6.9s - 7.0s) on pump gas @ 3700#s w/ driver:
- Ported OEM iron heads 270/210 cfm
- 9.8 CR
- 254/254 @ .050" solid flat-tappet cam
- Ported M1 intake w/ 80496-1 Holley "950" 1.375" v x 1.75" throttle
- 1-7/8" Hooker headers
- 9.5" 4200-stall Dynamic converter
- 4.10s
- 9" slicks
B. Next combination that went 10.5s (6.6s) on pump gas @ 3750#s w/ driver was same as above, except changed to:
- Ported MP Stage heads 305/235 cfm
- 10.8 CR
- 266/266 @ .050" solid flat-tappet cam
- Ported M1 intake w/ BG "Gold Claw" 1.425" v x 1.75" throttle
- 2" TTI headers
- 275/60R15 M/T ET Street Radials
Just be aware that my results came after a lot of tuning at the track to get the car dialed in, especially w/ the suspension so the car would 60-ft. reasonably well on small-ish tires. But in both cases these were running in full street trim (other than when I swapped to 9" slicks) on 93-octane pump fuel after driving the car to the track.
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: BradH] #1354772
12/19/12 05:30 PM
12/19/12 05:30 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
It can be done maybe a little more gear but tuned right should be ok
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: viperblue72] #1354773
12/19/12 07:09 PM
12/19/12 07:09 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
Hi guys. I haven't posted here in a while. I have a '72 cuda. So far I have put a 4.10 dana in place and 440 drivetrain. I plan to use alot of what I already have which is a fresh 440 crank, and source heads.
I am thinking some 0 deck flat tops for pump gas, have the source heads fully ported, and run a solid or solid roller. Also an at with 3500-4k stall.
I do plan to run fiberglass hood and bumpers but otherwise full body and interior (3400 pounds?)
With this stuff listed is 10.90s possible? HOw would you do it or what would you change?
My old Combo was a 3800lb B body on 9" slicks SS springs, 4000 stall 10", manual valve body trans, 516 heads with big valves, 590 cam and TRW 11.5-1 pistons. Ran 11.0's.
My last venture with a Buick motor I used CNC ported performer heads and a Scott Brown cam. Really surprised me how well it ran, similar combo with flat tops it ran 10.60's but would idle at 800 rpm no problem. I'd recommend Porting the heads, custom cam and/or possibly a 500" stroke kit and you should get there easily.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: d7cook] #1354774
12/19/12 10:04 PM
12/19/12 10:04 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
I prefer the ultradyne 309* 613" over the 590 cam. Had great luck with it.. I heard bullet sells these grinds now..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: HOTMOPR] #1354775
12/20/12 04:20 AM
12/20/12 04:20 AM
V
V
I always thought a .590 or similar cam would be overcammed for a 10.5 to 1 motor, but looks like people still had great success. I would love to get closer to 11.5 to 1, but i think id have to mill the heads quite a bit, and nobody sells a lightweight piston with a small dome. I may have to try one of these big solids, especially since I already have some isky ductile rockers. Fwiw I am also running a 950 holley and 1 7/8 headers for now.
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: viperblue72] #1354776
12/20/12 04:33 AM
12/20/12 04:33 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I was going to run the .590 but since I run 10.6 comp I called Dwayne Porter and had him spec a cam for my combo. It is actually close to the .590 but the valve timing plays an important part of it with cylinder pressure as the intake valve closing has alot to do with how much cylinder pressure it builds. And cylinder pressure has alot to do with running on pump gas. I feel I know alot about cams but I dont know what Dwayne Porter knows as he is very good and it seems every car I have seen with one of his cams runs better then I thought it should so thats one of the reasons I went with his cam. He is a pro and does this every day. His prices are very good and I wanted a custom cam speced for my combo. If you would decide to have a custom ground cam and wanted to talk with Dwayne just let me know as I have his phone #. Just an option you might consider to get the most out of your combo. There are many smart people on here but guys like Dwayne do it for a living every day and are pro's at specing a cam to a combo. Also if you do go with a solid flat tappet which I did have it nitrided as Dwanye suggested and did that to mine and also told me to run the EDM lifters which have a tiny hole on the lifter face that puts oil right on the cam lobe. Nothing wrong with the 950 carb as I only use an 850 right now. The 1-7/8 headers will do the job for you. Ron
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: 383man] #1354777
12/20/12 10:16 AM
12/20/12 10:16 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Back in the early 90s we had a 68' Barracuda @3380# w/driver....
440 block 4.375 x 4.15
906 ported iron heads
.590 MOPAR solid cam
M1 intake gasket matched w/2in spacer
Holley 9375 1050 dominator
BME rods
About 11 static compression w/flats
2in fenderwell headers
727
9in "J" converter
4.56 Dana
SS springs w/inboard
Mopar rear shocks.....Koni SPA-1 fronts
SS Hemi style scoop
31 x 12 Firestones
Drove the wheels off the car on the street and only had about 15 runs in that trim before we switched to 440-1s, a solid roller and good headers.
Raced it on cheapo Cam 2 110 because we had a station 3 miles away that had it at the pump for $4 a gallon, so it drank that, mostly......but it would drive around on 93 pump with no issue.
In decent air at ATCO, 10.06 @135+.
Most fun car I've ever owned......cheap to build and low maintenance.
It doesn't take much to run 10.90s if your in the 550+ range and your converter and gear aren't in left field, but 3400# might be light for your car, unless you've taken some steps to shed some weight.
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: jim sciortino] #1354778
12/20/12 11:17 AM
12/20/12 11:17 AM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
Hi ....everyone, nothing changes here ...well my combo has worked for me since I raced Gary Davis in 2004...10.90 and then some 3700 lbs I have had 3.73 to 4.30 and its pretty much the same...A good converter will work magic 8 ati changed everything for me
Re: How to get 10.90s pump gas 440 in a 'cuda [Re: HOTMOPR] #1354779
12/20/12 02:31 PM
12/20/12 02:31 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
That Ultradyne sure was a good cam. I ran the
Ultradyne .590-.613 made for heavy cars.
65 Sport Fury 4000 lbs.
440 Ross 10.5s
ported 452 heads
825 race Demon
M-1 intake
MSD ign.
9" 4200 J conv.
Dana 60 4.88 gear.
Hoosier 31" QTP
ran 11.16 in the heavy C body Fury.
Everyday driver on pump gas
Would of run 10.90s in a Cuda
Snap your neck, mega G-force launch, is all I want!
