BIG DOG ROTOR 11.75 X 1.25
#1352971
12/17/12 01:36 PM
12/17/12 01:36 PM
Posts: 220 Forth Worth, Texas, USA
TheRamMan
THE BIG DOG( 1.25 THICK ) ROTOR IS BEING FINALIZED...FITTING 2 SPINDLES 70-72 DISC SPINDLE 73- UP SPINDLE 1) REQUIRES LARGE PIN CALIPER BRACKETS( CHRYSLER PREVIOUSLY MADE ) 2) REQUIRES WIDE MOUTH PIN CALIPERS ( CHRYSLER PREVIOUSLY MADE ) 3) YES THIS MEGA ROTOR WILL BOLT RIGHT UP...WITH ALL 100% AVAILABLE CHRYSLER PARTS.....IT DWARFS THE STANDARD 11.75 ROTOR WHAT DO YOU THINK wayne@theramman.com
Re: BIG DOG ROTOR 11.75 X 1.25
[Re: TheRamMan]
#1352972
12/17/12 04:12 PM
12/17/12 04:12 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You're making a truck/van rotor with passenger car bearing bosses?
[Re: feets]
#1352976
12/17/12 05:45 PM
12/17/12 05:45 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Well, I haven't looked at the 72-73 stuff but the I bolted a set of 70 C body rotors on a set of 70 E body spindles & it was a direct bolt on...
[Re: 1_WILD_RT]
#1352977
12/17/12 07:16 PM
12/17/12 07:16 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
Imperials generally had different parts vs. the run of the mill C barge. So the only thing I can guess is mr. ramman discovered a supplier for the C body rotors ????
![](/ubbthreads/images/graemlins/blush.gif)
[Re: BDW]
#1352980
12/17/12 08:26 PM
12/17/12 08:26 PM
Posts: 2,431 SK,Canada
gregsrt
SK,Canada
Which calipers would they need?
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry.
Thomas Jefferson
[Re: AndyF]
#1352982
12/18/12 01:55 PM
12/18/12 01:55 PM
Posts: 413 Norway (old world)
Oyvind Mopar
Norway (old world)
With a 1.250 rotor the Viper caliper will bolt right on without requiring any pad spacers. There are some other aftermarket calipers that are also designed for the wider rotor.
Andy: Will the Viper calipers really bolt on to the typical B/E spindles? Are special wheels needed to clear these calipers? ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: Oyvind Mopar]
#1352983
12/18/12 03:22 PM
12/18/12 03:22 PM
JohnRR
Andy makes an adapter that allows the caliper to bolt on , though I'm not sure if that is for use with a 10" drum spindle ? I think it requires a 17" wheel , the caliper is pretty big .
Maybe I should let Andy answer? ![](/ubbthreads/images/graemlins/spank.gif)
[Re: AndyF]
#1352984
12/18/12 05:27 PM
12/18/12 05:27 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
TO touch on some things a bunch of other people have said: I've spent a lot of time perusing parts-store websites and bearing & seal catalogs in teh quest for 1. a cheap alternative to teh $150 69-72 c-body rotor, and 2. an 11" rotor that can be fitted onto a drum spindle so that it can all fit behind 14" wheels. All my efforts got stumped by either a different rotor that had narrow application and was just as expensive or I found a cheap rotor but couldn't find a seal that was compatible. Data: 65-70 C-drum, 69-72 C-disc, 70-72 Challenger: A2 and A6 bearings (disc or drum for Chally? My notes don't specify but probably drum, I'd have zero interest in putting E-body drums on a C-body drum-spindle ![](/ubbthreads/images/graemlins/laugh2.gif) ) 73 C-disc: A16 and A17 bearings 73-74 Chally: A2 and A17 bearings
[Re: dogdays]
#1352986
12/18/12 07:12 PM
12/18/12 07:12 PM
Fury Fan
Indiana
The problem with most modern rotors is that they are too flat - the 'hat' section is not tall enough to get the caliper back from the mountig surface, back into the rim. Modern cars have flat-faced wheels that account for this.
The 98-02 Vic rotor is one of the few that I've found to hold some promise, but yeah, it requires 16" wheels. It's also nice and thick, similar to a C-rotor. And it's doggone cheap!
I have a setup like this for research, but the packaging for a caliper bracket adapter plate is kinda ugly. I've looked at every combination of drum spindle, disc spindle, Vic caliper, C-body bracket & caliper, M-body bracket and caliper, and haven't found anything yet that I like.
The C-body hub works fine with this rotor after the drum is taken off (and that's 1 key to preserving OEM validation on the bearings and seals). Just need to enlarge the Vic rotor boltholes a bit.
If that rotor were 1/2" taller it would make a huge difference!
[Re: JohnRR]
#1352988
12/19/12 12:52 AM
12/19/12 12:52 AM
Posts: 31,105 Oregon
AndyF
The early Viper calipers bolt to the late drum knuckles with an adapter. Fits an 11.75 rotor and 15 inch wheels. I've been sellling that kit for at least 10 years. Figured everyone knew about it by now. The kit would work better with a 1.25 thick rotor. That would be a very capable front brake system that would still fit under a 15 inch rim.
