Which HEMI valve cover gasket?
#1351936
12/15/12 11:25 PM
12/15/12 11:25 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Need new V/C gaskets.What the latest & greatest??Is the Felpro the one with the steel between 2 layers of cork?? Mr gasket,cometic, ![](/ubbthreads/images/graemlins/image_294343.gif)
Re: Which HEMI valve cover gasket?
[Re: hemi-itis]
#1351937
12/15/12 11:35 PM
12/15/12 11:35 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I stock both the Superformance and Cometics....they both are very good gaskets....the Cometics are much like the old SBM V/C with the steel inners and rubber outer.
RIP Monte Smith
[Re: hemi-itis]
#1351939
12/16/12 08:09 AM
12/16/12 08:09 AM
Posts: 872 NJ
SSDAcuda
NJ
Al, I like the fel pro steel between cork: http://www.summitracing.com/parts/fel-1657/media/imagesA little pricey, but thick enough to seal and the steel holds the shape so it doesn't distort. I have the valve covers on/off alot and these lasted the whole season.
SS/DA 1924
[Re: SSDAcuda]
#1351940
12/16/12 08:44 AM
12/16/12 08:44 AM
Posts: 1,629 pa
572charger
pa
ray bartons on cast covers weather strip adheasive to the covers take em off and on no leaks
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: Cab_Burge]
#1351943
12/16/12 03:07 PM
12/16/12 03:07 PM
hemi-itis
The gaskets I had were so old I forgot who made them.They were the light brown cork with a steel center.The felpro's are blue silicon with the steel center.The regular cork ones like what are under my stock chrome covers on stock steel heads have crushed out in the lower corners and leak right onto the header.
[Re: Dap]
#1351946
12/16/12 11:13 PM
12/16/12 11:13 PM
hemi-itis
He did,with plain cork ones.The covers have been off many times since then.
[Re: hemi-itis]
#1351947
12/16/12 11:39 PM
12/16/12 11:39 PM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
Ok you had said that they were so old you forgot who made them I they were the ones that were on there. Got Ya ![](/ubbthreads/images/graemlins/wave.gif)
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
[Re: 68 HEMI GTS]
#1351949
12/17/12 01:26 AM
12/17/12 01:26 AM
hemi-itis
Will order them tomorrow and pick them up on tuesday ![](/ubbthreads/images/graemlins/thumbs.gif) Thank you ALL for your replies ![](/ubbthreads/images/graemlins/smoke.gif)
[Re: hemi-itis]
#1351950
12/17/12 02:05 AM
12/17/12 02:05 AM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
buy these and you can use silicone or a paper gasket and never see a drop of oil. I have them web page
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#1351951
12/17/12 03:21 AM
12/17/12 03:21 AM
Posts: 912 London, England
mopar_mark
London, England
web page
Fred, I got a set if those a couple of months ago, fit seems good,nice & flat,not run motor yet though. I have silicon gaskets
[Re: mopar_mark]
#1351953
12/17/12 04:23 PM
12/17/12 04:23 PM
mopar_mark
London, England
web page
![](http://i378.photobucket.com/albums/oo230/mopar_mark/HEMI%20CUDA%20-%20TWIN%20TURBO/DSC00690.jpg)
[Re: hemi-itis]
#1351955
12/17/12 10:41 PM
12/17/12 10:41 PM
mopar_mark
London, England
Mark,are the rockers under your cover?Do they clear without issues?? I had read some where someone's rockers were hitting the cover so I passed on the cheapo covers.I'd like to hear they clear everything to shed my fear of a no fit ![](/ubbthreads/images/graemlins/image_294343.gif)
Hi there, Yes, rocker gear(StageV) are fitted under the valve covers.
I have cranked motor by hand with valve covers fitted & no interference. I did measure, but can't recall what it was, as I was checking clearance for when I installed valve cover breathers.
On the route of breathers, I would most like buy weld in # bungs if doing again.
Like you I was apprehensive, but thought for the price, it was worth the risk, as it happened,all seems OK so far.
Fred has real world experience & If he says he's ran them & all is OK, that's good enough for me
