Re: aluminum main caps
[Re: dvw]
#1351661
12/18/12 07:36 PM
12/18/12 07:36 PM
Posts: 290 Norwalk Ohio
cudasteve68
Norwalk Ohio
For what it's Worth the only set I ever ran did have slightly less oil pressure at Idle when hot. This was using the same main clearance .003" as I use with steel caps. Doug
I have noticed the same issue in the late rounds, however you will notice a drop no matter what caps you use. I have found two answers to this problem, and they both work GREAT!!!!
1) Ride the Harley on race day & leave the Racecar in garage. 2) Become a first round runner up like me.
Both keep oil temps down & pressure up!!!
