Re: Felpro Head Gaskets for Big Block [Re: superwrench] #1351370
12/15/12 04:09 PM
12/15/12 04:09 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Fel-Pro claims it's .039" compressed, but I can't confirm that since I only have new gaskets to inspect. The new 17059 and 8519 I have were around .046-.048" IIRC, but I was mostly concerned w/ the bore dimensions at the time I did the comparison.
Another brand of BB head gaskets that were advertised as having a .038" compressed thickness measured .040-.042" when I pulled them off after my last tear-down, so I don't know how "exact" any manufacturer's claims of compressed thicknesses are for composition-type gaskets.
Re: Felpro Head Gaskets for Big Block [Re: superwrench] #1351371
12/15/12 04:27 PM
12/15/12 04:27 PM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
http://www.summitracing.com/parts/dcc-4349559/overview/
These are 1009's reboxed. I have them on my engine.
Re: Felpro Head Gaskets for Big Block [Re: BradH] #1351372
12/15/12 04:59 PM
12/15/12 04:59 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Any signs of brinelling (indenting) around the chambers w/ the 17059 Marine-spec gasket? I thought that was only an issue w/ the 1009 because of the built-in steel o-ring in the fire ring.
FWIW, the 17059 and the 8519s have identical dimensions (4.50" bore & ~ .040" compressed thickness), but different construction materials. I have a set of both on hand and verified the bore dimensions and UNcompressed thickness, but don't have any used ones to check compressed thickness.
Also, according to Fel-Pro's tech papers, their Marine-spec head gaskets are made the same as the race series (like the 1009), except they don't have the steel o-rings in the fire rings.
The fire ring did leave an indentation on the heads and I put em back together as they were...........not a problem.
Re: Felpro Head Gaskets for Big Block [Re: superwrench] #1351373
12/16/12 12:01 PM
12/16/12 12:01 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The 8519s would have worked on my heads.They are the very first ones made.Later ones had the chambers redesigned.Id have used the 19s but with the 12.5 domes I wanted the better Marines.Rocky
Chrysler Firepower
Re: Felpro Head Gaskets for Big Block [Re: super451b] #1351374
12/16/12 01:19 PM
12/16/12 01:19 PM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
Re: Felpro Head Gaskets for Big Block [Re: PLUM BAD] #1351375
12/18/12 04:49 AM
12/18/12 04:49 AM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
Hello I justed pick up a pr of 1009,s from Summit Racing , They were rebox from Mopar part number is DCC 4349559 FOR $59.95 PLUS SHIPPING. I also order a pr from my Dodge dealer for $59.95 with no shipping. Thanks Moparts I,am $20.00 to the good!! ea from Summit was $42.00 and at my local parts store was $40.00 ea
