Page 3 of 8 1 2 3 4 5 6 7 8
Re: B1's - Why not more popular for Big strokers?? [Re: Biginchmopar] #1350201
12/12/12 07:28 PM
12/12/12 07:28 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Ok, let me turn it around a little....
What if Koffrll, Indy, Eddie or whoever gave Us a BBM head which combined max wedge ports (standard intakes will fit ) BUT also gave us a W / B1 style valve arrangement that opened on the bore center and a more favorable for flow Valve angle?
How hard would it be? Lets assume you're gonna need B1 style pistons? Maybe less a B1 but maybe more of a Scaled-up W8? 2.30 intake valve and 380+ cfm
I was always vexed by why the aftermarket couldn't fix the 1958 valve angles. Look at all the Cleveland/Windsor/twisted wedge choices the Ford guys have. Look at a set of CHI Clevor heads some time,
Keep the shaft, center up them valves!!
Mopar answered your request except for moving the valves.
Mopar Stage VI CNC ported by Chapman flowed 385cfm with a 2.250" valve
Nobody bought those either.
Wise has them on his 517 , I had a set , the issue was the price, most mopar owners want pro stock HP on a small block chevy budget.
Mopar dropped the ball on the stage VI , they designed it around the stock wedge head valve length , what IDIOT at MOPAR thought that was a grand idea ?
Re: B1's - Why not more popular for Big strokers?? [Re: camastomcat] #1350202
12/12/12 07:32 PM
12/12/12 07:32 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Some people here think their -1 heads flow 380 or more.
some people on here do have -1's that go 380 or more.....................
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: B1's - Why not more popular for Big strokers?? [Re: bigtimeauto] #1350203
12/12/12 08:07 PM
12/12/12 08:07 PM
gregsdart Offline
gregsdart  Offline
Looking back, a lot of us got backed into the replacement type (SR,440-1,Eddys,etc) simply because they fit some of our parts OR, were familiar. A B1 seemed out of reach at the time because it required going the whole way. New pistons, valvetrain, intake, the whole topend plus pistons plus drain lines, ETC. Forgot to mention a converter change would also probably be part of the change. Add $1200 to the changeover. Advertising made a huge difference as well, and the Indy stuff and Edelbrock stuff well promoted.
If you look at what can be done with a well worked 440-1 or 572-13 they make more sense for a 500 to 550 inch street motor because the torque peak is about 1000 rpm less on a 528 cube motor. A 440-1 will peak about 4900, B1 5900? So to my thinking the B1 is better suited to a huge(by yesterdays standards)street motor, 572 and up. Sure you can make the B1 run OK at 4500 rpm with a 500 cube motor, but the smaller port motor will pull harder there. I am still hoping someone with real world experience on a flat tappet/B1 combo would chime in to show what could be done on a smaller budget. With a 541 cube stock block, B1 heads and a big flat tappet cam, I would think that combo may have an edge over the Indy stuff within the range of the flat tappet cam. Specifically the Comp 650 lift, 290 cam. You can get by with the standard B1 rockers, the cam is cheap, and should rev to 6800 reliably.
Re: B1's - Why not more popular for Big strokers?? [Re: bigtimeauto] #1350204
12/12/12 08:08 PM
12/12/12 08:08 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
My flow sheet says MORE than 380 on a 4.375 bore/fixture...
....BAD A$$ STREET CAR.....
Re: B1's - Why not more popular for Big strokers?? [Re: n20mstr] #1350205
12/12/12 08:31 PM
12/12/12 08:31 PM
gregsdart Offline
gregsdart  Offline
Most good porters can get 375 to 380 cfm out of them, with a 2.25 intake. Mine flow 399/400 at huge lift due to using a 2.30 intake valve (.800/.900) but with the cam and port remaining the same the car never went faster. The flow with the bigger intake valve also had a weak spot where the flow at about .300 stayed exactly the same, so that might have been part of the reason the car never liked the change.
Re: B1's - Why not more popular for Big strokers?? [Re: n20mstr] #1350206
12/12/12 08:32 PM
12/12/12 08:32 PM
Weddington, N.C.
Streetwize Offline OP
Weddington, N.C.
I hear you on the Chapmans and yes, I do have a set on the 517 low deck. 380cfm at ~.700 is great but it's the 335 @.500 and the 361 at only .600 that makes them the killer head for 500 cubes.
I've done The Indy -1's and since even full CNC'ed they wouldn't be much ( if any ) 'measurable' bit better than what I already have, I think they would be too small for what I'd want to do with a 572, essentially the same power at 500 rpm lower but with more torque...when the 500 already has all I need.
The 572 B1 I would think would be the next '1 step beyond 'what I have, more flow/volume for a proportional increase in cubes, obviously needing a bigger cam for the extra cubes but would still allow me to pull past 7k. The thing about strokers is once they run out of head the torque noses over at a very fast rate ( all that extra stroke/piston speed and ring drag starts to work against you) since past the torque (VE) peak the crank's rate of acceleration slows and the rings start to act like a brake. ( Also true for all 4cycle motors) That's why I always build for the widest possible torque curve, simply because it's more fun to drive.
The bore/valve centerlines and wedge angles are the key to the B1, if you scale down the port Cc and flow numbers to any comparable Conventional valve placement BBM head, it would still out torque and power it by virtue of the superior cylinder filling and evacuation efficiency. the chamber/valve placement is also generally why the small block makes more power per cube than the conventional big block all else being equal. The B1 design 'evens the playing field' I think
WIZE
In Car:
Re: B1's - Why not more popular for Big strokers?? [Re: Streetwize] #1350207
12/12/12 08:36 PM
12/12/12 08:36 PM
N
n20mstr Offline
n20mstr  Offline
N
cant pistons be cut (valve reliefs) to fit a B! where a 440-1 once was?
Re: B1's - Why not more popular for Big strokers?? [Re: n20mstr] #1350208
12/12/12 09:14 PM
12/12/12 09:14 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Bring back the Chapmans!
Mopar to the bone!!!
Re: B1's - Why not more popular for Big strokers?? [Re: n20mstr] #1350209
12/12/12 09:16 PM
12/12/12 09:16 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
The flow sheet on my B1 originals with a stage 1 port job showed these flow numbers at these lifts
.500 344.25 cfm
.600 364.50
.700 393.75
.800 385.20
I have around 13.5 comp. I was having trouble figuring out a cam for my car, so asking here, Koffels, and comp, I had this special cam built for the car. This being my first B1 engine. I wasn't sure what to have built, it being a 4.37 bore 7.1 rod and 4.25 stroke. I bought a 6200 stall for my glide off of Chrisbarracuda since it was recomended for this cam grind.
Does this look like a good combo?
.775 in .766 ex
timing at .050
int 29 btdc 75 atdc
exh 82 bbdc 36 atdc
113.0 intake center line
Dur. at .050 int 284 exh 298
lobe lift .4560 exh .451
Lobe seperation at 113.0
I use 1.7 rockers, How does this combo look to some of you guys? Is it a good choice? Or does anyone see room for improovement? I'm just starting to run bracket races with my car and still tuning. Car is around 2750 lbs. It feels good to me, for what I built ?
So this is what i'm running with now.
Re: B1's - Why not more popular for Big strokers?? [Re: Mopar-Al] #1350210
12/12/12 09:25 PM
12/12/12 09:25 PM
Weddington, N.C.
Weddington, N.C.
Looks like a solid combo, curious about the wide and late LSA and ICL but lifts and dirations look good. Flow is only slightly better than my Chapmans but I'm betting the power up high is better since the chamber and valve placement is more efficient. It's a light car so I'm thinking the engine builder is trying to spread the torque and pull as much top end out of as possible.
Btw, thanks to EVERYBODY for the great tech on this thread, sometimes ya just toss an idea out there and see what the tide brings in
WIZE
In Car:
Re: B1's - Why not more popular for Big strokers?? [Re: Streetwize] #1350211
12/12/12 09:35 PM
12/12/12 09:35 PM
tboomer Online work
tboomer  Online Work
Great thread,guys! Maybe I should ask Radar his thoughts on these heads the next time I see him.
Re: B1's - Why not more popular for Big strokers?? [Re: Streetwize] #1350212
12/12/12 09:47 PM
12/12/12 09:47 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Some of us prefer wider LSA #'s..They work, in my opinion narrow LSA's(108, 110)are an old way of thinking. My current B1 Bullet cam is on a 114. Wide LSA's are not just for power adders
Re: B1's - Why not more popular for Big strokers?? [Re: Al_Alguire] #1350213
12/12/12 10:55 PM
12/12/12 10:55 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
shhh your on moparts!
Re: B1's - Why not more popular for Big strokers?? [Re: gregsdart] #1350214
12/12/12 10:57 PM
12/12/12 10:57 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I don't think there is enough port volume for your combo on alky.
Re: B1's - Why not more popular for Big strokers?? [Re: n20mstr] #1350215
12/12/12 11:14 PM
12/12/12 11:14 PM
Wild West
M_D Offline
M_D  Offline
Wild West
If there is enough material on the piston dome and the rings are not too high they can be cut. Otherwise B1 valve pockets tend to break through into the top ring land and/or leave some pretty thin spots on the dome.
Re: B1's - Why not more popular for Big strokers?? [Re: M_D] #1350216
12/13/12 12:39 AM
12/13/12 12:39 AM
campbell river B.C
mopartoby Offline
mopartoby  Offline
campbell river B.C
Great post!!! My 605 b1/mc motor is being built by mike and eric. Hopefully it will see the dyno next week. I chose the b1 stuff because i called and emailed indy to ask a few q's about there heads and never got a reply! The head castings themselves are cheap through koffels. Its the finishing part that costs the $$$$! And in my case custom pistons had to be purchased anyways as soon as it hits the dyno i'll post some results!!
Re: B1's - Why not more popular for Big strokers?? [Re: Streetwize] #1350217
12/13/12 01:02 AM
12/13/12 01:02 AM
gregsdart Offline
gregsdart  Offline
I have virtually the same cam within 2 degrees. Mine is 283/296/112 in at 110 and .7750 intake lift, .680 on the exhuast. Comp spec'd my install centerline at 108 with this cam, 528 cubes and 440-1 heads. I run it at 110 though.
Re: B1's - Why not more popular for Big strokers?? [Re: mopartoby] #1350218
12/13/12 01:04 AM
12/13/12 01:04 AM
gregsdart Offline
gregsdart  Offline
Good combo!
Re: B1's - Why not more popular for Big strokers?? [Re: gregsdart] #1350219
12/13/12 01:45 AM
12/13/12 01:45 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
20 plus year old heads . If you have to ask then you are stuck in a time warp feeding the dated zombie Mopar hoard. I find it way more offencive that we don't have any more heads to chose from in the past 10 years . The B1 heads should be parked right next to the MC hammer pants.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: B1's - Why not more popular for Big strokers?? [Re: go green] #1350220
12/13/12 03:41 AM
12/13/12 03:41 AM
campbell river B.C
mopartoby Offline
mopartoby  Offline
campbell river B.C
You're almost right, they are a bit old school but they work very well!! And your predators work even better. But no way i'll fork out that kinda loot for that little gain over the b1's.
