Re: 15x12 under a 68 dart stock frame rails? Pix please
[Re: mikeysmopars]
#1349833
12/13/12 08:43 PM
12/13/12 08:43 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I run a 31x10.5 and i think it's a W because i dont believe hoosier do another tyre in that size. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Thumperdart]
#1349835
12/16/12 05:26 PM
12/16/12 05:26 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
I run a 17 x 11 with 7 inches of backspacing. Each side is like 1.25 narrower than stock. A 12 will fit a minitubbed Dart with perfect backspacing, just depends on your rear end width. My tire is a 345/40/17, rated 27.7, 13.7 section on a 12" wheel, on my 11 its probably barely narrower, and it only rubs under articulation on the inner tub. Anything over 13.5 is basically at the limit unless you have square tubs.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
