Re: 15x12 under a 68 dart stock frame rails? Pix please [Re: topside] #1349832
12/13/12 08:30 PM
12/13/12 08:30 PM
fresno ca
mikeysmopars Offline OP
fresno ca
Idealy, I'd like to run 15x12 wheel and have a 30"tall x 12" footprint, The section width will be the issue i think.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: 15x12 under a 68 dart stock frame rails? Pix please [Re: mikeysmopars] #1349833
12/13/12 08:43 PM
12/13/12 08:43 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I run a 31x10.5 and i think it's a W because i dont believe hoosier do another tyre in that size.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: 15x12 under a 68 dart stock frame rails? Pix please [Re: mikeysmopars] #1349834
12/16/12 05:09 PM
12/16/12 05:09 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No photos but I had a 12" rim w/stock width housing and w/a 7 1/2" backspacing it fit but was tight and that`s why I went to 10" rims............ Mikey, can you show me that engine bay photo again as I have no clue which post that was on..........
Re: 15x12 under a 68 dart stock frame rails? Pix please [Re: Thumperdart] #1349835
12/16/12 05:26 PM
12/16/12 05:26 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
I run a 17 x 11 with 7 inches of backspacing. Each side is like 1.25 narrower than stock. A 12 will fit a minitubbed Dart with perfect backspacing, just depends on your rear end width.
My tire is a 345/40/17, rated 27.7, 13.7 section on a 12" wheel, on my 11 its probably barely narrower, and it only rubs under articulation on the inner tub. Anything over 13.5 is basically at the limit unless you have square tubs.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: 15x12 under a 68 dart stock frame rails? Pix please [Re: topfueldart] #1349836
12/17/12 10:56 AM
12/17/12 10:56 AM
Out West
408strokerdart Offline
Out West
I notched the rear frame rails about 1" and run 31.25 MT raidal slicks on 12" wheels easy. Going to beadlock a 14" wheel down to 13" and should still leave plenty of room. I think it has been said here already....the right backspace for your set-up is critical to getting it to fit.
Re: 15x12 under a 68 dart stock frame rails? Pix please [Re: 408strokerdart] #1349837
12/17/12 12:01 PM
12/17/12 12:01 PM
fresno ca
fresno ca
Thanks Brian, Was hoping you would chime in. Your car looks to have been backhalfed, The biggest dilema is most of the wheel company's make thier wheels in 2" incriments so if a 15x11 is the easiest way out looks like i'd have to have them made. But i thought about notching the rails like you said, that would give me plenty of room even with section width.
Re: 15x12 under a 68 dart stock frame rails? Pix please [Re: mikeysmopars] #1349838
12/17/12 12:55 PM
12/17/12 12:55 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My cars is way better since I ditched the 12`s and went w/the 10`s...........more room and hooks no worse than before and street driving is much more pleasureable especially w/passengers.
