Re: 590HP W2 headed pump gas 408 on the dyno...
[Re: B3422W5]
#1347197
12/07/12 09:46 PM
12/07/12 09:46 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I like tight lca's most times but everything is a compromise! A smaller cam on a tighter lca would make more lower rpm power I'm sure, but for street cars traction is limited on the STREET so actually a good race HP and TQ curve work well. At the track, sure more poop on the line would be nice, but I'll bet the engine spends most of it's time in the 5000-7000rpm range and with a 4" crank even if the 60ft. is a little soft it'll e.t. better this way than the other.
Brian Hafliger
[Re: Stroker Scamp]
#1347199
12/07/12 11:03 PM
12/07/12 11:03 PM
That man knows what he is doing!!!--Nice build--amazing results! I love a unit that revs like a chainsaw!!!
[Re: mshred]
#1347204
12/08/12 04:03 PM
12/08/12 04:03 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Most dyno videos are boring but I really enjoyed this one, engine sounds great! ![](/ubbthreads/images/graemlins/thumbs.gif) That will be a blast in a fairly light weight car.
[Re: ProSport]
#1347205
12/08/12 08:03 PM
12/08/12 08:03 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Thanks Pro...Matt I would guess around 25-30HP maybe...as smooth as these lobes are, not sure it would be a huge amount. Remember, the heads were only mildly ported so there's some power left on the table there.
Brian Hafliger
[Re: Brian Hafliger]
#1347206
12/08/12 10:38 PM
12/08/12 10:38 PM
Posts: 3,427 Toronto
mshred
Toronto
Cool, I was just wondering if the solid roller helped make substantially more power if it was to be up against a similar flat tappet. Motor sounds BAD when it is revving ![](/ubbthreads/images/graemlins/thumbs.gif)
