Page 2 of 3 1 2 3
Re: Would you choose a 318 or 360? [Re: Skid_Demon] #1345896
12/05/12 11:02 AM
12/05/12 11:02 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Wow, great information. If I can find the magnum, what do I need to do to switch from EFI to carb? Any idea on cost? Thanks.
an intake, carb, and carb distributor from an LA 318
2017 Grand Cherokee Overland
Re: Would you choose a 318 or 360? [Re: Skid_Demon] #1345897
12/05/12 11:24 AM
12/05/12 11:24 AM
Doniphan, Nebraska
Lmopar69 Offline
Lmopar69  Offline
Doniphan, Nebraska
Interesting. Im doing the exact same thing. Mine is a 46 Dodge truck, now with IFS, boxed frame, 8.75 rear. I am trying to find a 96 or newer v-8, 5 spd, 2wd Ram to use as a engine/trans donor. I would much rather have a 5 speed than a auto. surprised at how hard it is to find a manual trans truck cheaply.
I'd love to see some pictures of yours.
Laine.
Re: Would you choose a 318 or 360? [Re: Lmopar69] #1345898
12/05/12 12:34 PM
12/05/12 12:34 PM
dogdays Offline
dogdays  Offline
We're at the horsepower wars again! I maintain a 318 with a medium sized four barrel carb and dual exhaust, using 360 pickup truck manifolds or whatever'll fit, is the ticket to get this rig on the road. If you want a little more power swap in a 360 cam at the same time, will be a good starter motor. It should make around 250 hp which is plenty to keep a 3000 or less pound pickup going down the road.
Yes, there are plenty of options. Bt they will all be worthless until you actually start driving the pickup!
I speak from experience. I have started plenty of projects by building an engine and have yet to drive most of them, although the engines look nice hanging on motor stands!
R.
Re: Would you choose a 318 or 360? [Re: dogdays] #1345899
12/05/12 12:51 PM
12/05/12 12:51 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
With mu history of actually getting vehicles running and driving I have come to the conclusion that I will always go with the best option to get the vehicle running and driving ASAP! GO with the 318 and get the car motivating, then if you want more power take your time and find the right engine and build it the way you want!
JB Rhinehart, Realist
A-Body's RULE!
Re: Would you choose a 318 or 360? [Re: Skid_Demon] #1345900
12/05/12 02:40 PM
12/05/12 02:40 PM
east side of Ohio
basketcase Online content
basketcase  Online Content
east side of Ohio
I've got my uncle's old '86 D100. 318 that he added a MP cam(one step above stock) and intake, Eddy 4 barrel. dual exhaust. It's no big block by any means, but it sure runs better than any other 318 I ever had.
agre with the 360 being overworked in the MH, and the hassel with having to scrap the remains.
1981 Dodge D150 360 auto
Re: Would you choose a 318 or 360? [Re: BulletBob] #1345901
12/05/12 03:50 PM
12/05/12 03:50 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The cost depends on whether you use the original serpentine Mag stuff or 78back LA V belt drive
The V list is as follows
Crosswinds intake $180.00
Cam snout extension 23.00
LA timing cover,Brackets & pulleys/fuel pump
Serpentine list
Edelbrock RPM Air-Gap $322.50
Carter 4070 Electric fuel pump $78.00
The Crosswinds is a direct bolt on with a RV2 compressor brackets
The Edelbrock needs spacers made & different bolts to attach A/C brace & Alt brace
I own both
Most of that stuff is not needed. You can redrill your heads to accept any LA intake manifold. The angle the intake bolts go in is different. Or you can buy one of the intakes on the market that will fit the magnum heads and take a carb. Those are a little more spendy at around 300 bucks. Don't need the LA timing cover, brakets and all that stuff unless you want it for looks. To run the serpentine stuff I just junked the AC compressor and bought a belt for a non-ac 3.9 magnum truck. I had to slightly reposition the tensioner but no big deal. No cam snout extension needed, buy an electric fuel pump which I much prefer to run instead of a mechanical one anyway. If you can do a little bit of wiring and can find a 92-95 dodge truck/ram van at the junkyard you can snag the engine harness and computer out of it and even keep the efi. This way no changes to the engine are needed. My donor engine is out of a 99 dakota but I grabbed the electronics from a 95 because they're easy to swap in.
Re: Would you choose a 318 or 360? [Re: patrick] #1345902
12/05/12 08:46 PM
12/05/12 08:46 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Go with the 318. I’m doing a 55 dodge truck and was planning on using a magnum 318 until I found a low mileage (66,000) totaled 03 Ram with a 5.7 Hemi in it for cheap.
Re: Would you choose a 318 or 360? [Re: DaytonaTurbo] #1345903
12/05/12 08:52 PM
12/05/12 08:52 PM
NW Pennsylvania
areibel Offline
areibel  Offline
NW Pennsylvania
I'm looking at doing the same swap in a '69 B body, the Magnum motor sounds perfect. I do have a couple other questions though.
First, what motor mounts would you need, the stockers (that need replaced anyways) or something different?
I was planning on using the stock 904 and converter, any issues?
And this is an AC car. If I find a motor with the AC condenser on it
would that make it remotely possible to go with an R134 set up (If I snag the expansion valve and drier, etc..). I guess I'm asking if the old evaporator and condenser would work with the new spinnin parts??
Thanks!
Re: Would you choose a 318 or 360? [Re: Skid_Demon] #1345904
12/05/12 11:29 PM
12/05/12 11:29 PM
Slantytown
DUFFMAN Offline
Ask And Ye Shall Receive
DUFFMAN  Offline
Slantytown
I'd go with a Megasquirt kit and keep the Magnum MPFI if you can fit the barrel intake under the hood. It would be cheaper than an intake and carb with all the advantages of fuel injection.
No longer taking $h!t from anyone!
Re: Would you choose a 318 or 360? [Re: areibel] #1345905
12/06/12 01:49 AM
12/06/12 01:49 AM
Manitoba, Canada
Manitoba, Canada
Thanks!
Magnums still have the old LA style mounting ears on them so they will accept stock motor mounts. I don't see any reason your old evaporator and condensor couldn't be reused with the magnum compressor. The expansion valve system is likely different because I don't think the newer ones use the valve on the evaporator like the old ones and I don't know enough about them to make a suggestion on that. Biggest challenge would probably be having custom hoses made to mate everything together.
Re: Would you choose a 318 or 360? [Re: DaytonaTurbo] #1345906
12/06/12 02:06 PM
12/06/12 02:06 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
What is the end goal aside from a summer driver right now? Do you see yourself tearing back into this for upgrades? If this is going to be a do-it-once-and-forget-about-it project, then Magnum all the way. Pound for pound, you're going to get better mileage and power from one when compared to a similarly built LA.
If it were me, I'd find a 318 Magnum, freshen it up while keeping the stock internals and drive it. Just a 4bbl and headers on one of these will put you around 250 horses.
If this an evolving project, drop the LA 318 into it for now and enjoy.
Re: Would you choose a 318 or 360? [Re: DPelletier] #1345907
12/06/12 02:22 PM
12/06/12 02:22 PM
Depends what you want, but yeah, the 360 will feel stronger. At the end of the day, 42 cu in is 42 cu in and there really IS no replacement for displacement.
If you want to go with a mid-90's magnum small block, I'd look for a 360. My old 1994 Ram with a 360 was more than half a second quicker in the quarter than a same-year 318 even though it only had ten more peak hp.
Re: Would you choose a 318 or 360? #1345908
12/07/12 12:45 AM
12/07/12 12:45 AM
Manitoba, Canada
Manitoba, Canada
I would have to agree, however I found it much harder to find a 360, especially if it was one I wanted to hear running first. I ended up finding a guy parting out a dakota that was still running and half way complete so I went for that. Some say the mag 360's are notably heavier on fuel, others say they're very close. In the end even the mag 318 is going to have more power than an old LA 360.
Re: Would you choose a 318 or 360? [Re: DaytonaTurbo] #1345909
12/07/12 12:00 PM
12/07/12 12:00 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
well, a 318 magnum with bolt ons will push a 2ED dakota to low 14's, maybe even nip the 13's...my old '96 ram 2WD long bed, at 4700 lbs plus my 230lb butt in it pulled low 16's and all I had was a cat back, MP computer, and 14" open element air cleaner. similarly equipped 360/auto 4x4 rams were mid-upper 16's, and extended cab 360/auto 4x4's were low 17's....
my dad traded in his '97 regular cab 4x4 with a 318 for a '01 extended cab with a 360 and regretted it. didn't pull his boat any better, but he went from 19-20mpg highway and 15-16 mixed to 15-16 highway and 12 mixed.
for a cruiser, a magnum 318 will have more than enough power (about the same as an LA360) but significantly better fuel economy. and magnum 318's are a lot easier and cheaper to find than 360 magnums.
Re: Would you choose a 318 or 360? [Re: patrick] #1345910
12/07/12 01:06 PM
12/07/12 01:06 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
"enough power" is highly subjective; "enough" for you might be nowhere near enough for someone else. In any case, all things being equal (LA318 to LA360 or magnum 318 to magnum 360) the additional 42 cubes is noticable and yes, I've had both.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Would you choose a 318 or 360? [Re: DPelletier] #1345911
12/07/12 03:55 PM
12/07/12 03:55 PM
Manitoba, Canada
Manitoba, Canada
If a magnum 318 isn't "enough" power for your drive, IMO the mag 360 won't be either. There is a difference in power, but not that dramatic. We're not talking 100hp/torq increase.
Re: Would you choose a 318 or 360? [Re: DaytonaTurbo] #1345912
12/07/12 04:20 PM
12/07/12 04:20 PM
DPelletier Offline
DPelletier  Offline
now it's a definition of "dramatic"! yep, you're right, only 10-15%. whether that's "a little", "a lot", "noticable", "worthwhile" or "dramatic" depends on your perspective.
I'm just saying that everything else being equal, I'll go with the 360 over a 318 just like I'll take a 440 over a 383.
None of those are particularly expensive or hard to come by.
Re: Would you choose a 318 or 360? [Re: DPelletier] #1345913
12/07/12 10:10 PM
12/07/12 10:10 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Dave's right & there are just as many 360's as there are 318's
If it's a Mag around here on the CL the $$ are 350-500 for good hear them run engines
I buy running & sometimes driving trucks & vans for 600-900 with them in em
Thow a 92-95 harness on it & ride sounds good but in reality takes a donor truck to work right & requires a speed sensor adaptor to have a speedo & in the end a carbed one will out perform & get better mpg with less work
Re: Would you choose a 318 or 360? [Re: BulletBob] #1345914
12/07/12 10:15 PM
12/07/12 10:15 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
318 magnum lighter car,360 magnum heavier car
Re: Would you choose a 318 or 360? [Re: d-150] #1345915
12/07/12 10:50 PM
12/07/12 10:50 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I took a 360 Mag from a SWB 97 Sport & put a carb on it hooked it to a 46rh & got 19 MPG in a lowered LWB 77 CrewCab w/4.10's. the truck it came out of had 3.55's & best it ever done was 17 mpg
Page 2 of 3 1 2 3
