bottom end turturer
#1345321
12/03/12 10:46 AM
12/03/12 10:46 AM
Posts: 281 NEW HAMPSHIRE AND MAINE
BIGSTROKER
hope u guy can help I put together a nos 440 shot block 1978 vintage that had no crank, I had a cast crank so I turned it 10 10 and put it in. I ran it for a while maybe a half hour and took it for a spin oil pressure slowly degraded down to 0 at a idle then got main bearing knock after finding a lot of crap in the oil I pulled the motor and found the 4 and 6 rod and the thrust wiped not spun no heat color just down to the copper and ground up but I could not find any reason for it. caught it just in time no crank damage.so I cleaned up the mess thru the block in the dishwasher polished the crank checked all the oil galleys in the block and crank 100 times and everything looked ok. so I put it back together I had 2.5 on the mains and 2 on the rods and 4 on the end play. I fired it back up and had 80lbs cold with 20w 50 and 35 to 40 at a hot idle maxing out at 70 lbs when the revs come up. then one of the hyd lifters starting hammering away so I got paranoid because the first time I had a loud lifter right out of the gun. so I drained the oil and I found metal again not so bad as before but at the end of the drain and in the filter it looked like silver fence paint. any ideas? do you think this Christine motor is going south again? I could spin the crank by hand before I put the rods in, real easy and smooth, after I loaded the pistons in I could spin the motor with my finger on the wrench real nice.no oil galleys were blocked I put my brush in from on end to the other on every one and blew them out with air.all the oil galley plugs are in no leaks I used good assy lube and I primed the motor with a drill both times and I spun the motor over with the starter and no plugs before I started it until the oil came up.
Re: bottom end turcher
[Re: BIGSTROKER]
#1345324
12/03/12 12:21 PM
12/03/12 12:21 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
" silver fence paint"....means you need to pull it back out and apart. I'd suggest enlisting some experienced help from your machinist or a builder on the re-build. good luck... ![](/ubbthreads/images/graemlins/thumbs.gif)
RIP Monte Smith
[Re: JD Dart]
#1345331
12/03/12 08:04 PM
12/03/12 08:04 PM
BIGSTROKER
well the oil pressure held it's own this time aroun it's just the junk in the pan thats bothering me there wasn't much but there should not be any! i drained the oil in a black pan then dumped it out and on the bottem of the pan i could see some specs of bebris and silver very little but still
[Re: Mopar-Al]
#1345333
12/03/12 08:24 PM
12/03/12 08:24 PM
Posts: 3,054 Bowling Green, KY
cudaboy
Bowling Green, KY
turcher
No offense, but I am still trying to figure out what this word is supposed to be? LOL
Dennis
[Re: BIGSTROKER]
#1345336
12/03/12 08:32 PM
12/03/12 08:32 PM
Posts: 6,780 Alabama
Mopar-Al
Alabama
everything was very clean and new both times 516 heads with 2.14 1.81 valves all done up
Torture ![](/ubbthreads/images/graemlins/beer.gif)
The oil holes on the heads that lead up to the rockers, did you blow out both holes on both heads? 1 hole tends to stop up as it is only used on one side. If you crossed up the heads, and didnt check the hole, then it can be plugged up. But it didnt cause you to spin the bearings, but will hamper flow to the rockers
[Re: BIGSTROKER]
#1345338
12/03/12 08:55 PM
12/03/12 08:55 PM
Mopar-Al
Alabama
everything oiled nicely when i primed the motor with the drill i had 80 lbs
I know, I read that, but have you checked your oil pump? They can go bad on the relief.
I guess what I'm saying is if you have checked everything over and over and it all apears good, throw away that POS block and find another. Christine may just reside under your black cloudy day. Anything that has been asked, you say been there done that.
