Re: Proportioning valve [Re: Runnin74] #1344741
12/05/12 09:27 AM
12/05/12 09:27 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Holy Crap! I used my coat hanger to tap from the stem end and out she came. I thought that the metered orifice on the rear brake side was pressed in but it was the shuttle. Major A-ha moment. The inside is pretty clean with no chunks just a tiny bit of sludge. This was my major concern. I could get some new O ring, and probably will, but they look pretty good and are tight.
Like Crap Game said in Kelley's Heroes, "You get a cookie."
Thanks Greg and everyone
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Proportioning valve [Re: cdstl] #1344742
12/05/12 01:13 PM
12/05/12 01:13 PM
St Louis, Missouri
Runnin74 Offline
Runnin74  Offline
St Louis, Missouri
Glad it worked out!
Make sure you check the bore of the cylinder that holds the piston with the cup on it that is retained with the blind plug. The one that is pointed down when the P valve is installed. In mine that cup was pretty eaten up and the bore was pitted. I think water collects there as it is the lowest point in the system when it is installed.
Re: Proportioning valve [Re: Runnin74] #1344743
12/05/12 11:30 PM
12/05/12 11:30 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
A lot of misuse of the word proportioning valve here. Not sure of this from the pics but most where safety valves so when a line broke shuttle would slide over and shut that side off, prop valves where down stream on rear line, usually v looking thing. I have heard of guys removing these dist valves, big no-no.
Re: Proportioning valve [Re: cudaman1969] #1344744
12/06/12 05:11 AM
12/06/12 05:11 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Actually most cars from the early 70's and up call them a combination valve many times as it has the dual funtion switch to move over and turn the brake lite on if you loose one side of the system but they also have the prop valve and a metering valve in that valve. The metering valve is only with disc brakes. Ron
Re: Proportioning valve [Re: cudaman1969] #1344745
12/06/12 07:50 AM
12/06/12 07:50 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Proportioning has been used generically here. In my first post I described the valve as a Brake Warning/Proportioning/Metering Valve. The Proportioning part of this valve is in Runnin74's picture above. It is the greenish piece with the spring wrapped around it and laying vertically in the picture.
I ended up RPMing my housing and putting everything back together. Hopefully this weekend I will be able to put everything back together and see what I have.
Re: Proportioning valve [Re: cdstl] #1344746
12/06/12 12:29 PM
12/06/12 12:29 PM
St Louis, Missouri
Runnin74 Offline
Runnin74  Offline
St Louis, Missouri
Let us know how it works out. Did you replace the o-rings and cups? If so where did you source the cups? The cup for the proportioning part of my valve is bad so I am looking for replacements.
Re: Proportioning valve [Re: Runnin74] #1344747
12/06/12 06:18 PM
12/06/12 06:18 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I didn't replace anything. Everything looked good so I decided to put it back together and not end up with some wrong sized O rings that would bind.
Will let you know....
