Re: Proportioning valve
[Re: Runnin74]
#1344741
12/05/12 09:27 AM
12/05/12 09:27 AM
Posts: 1,487 STL
cdstl
STL
Holy Crap! I used my coat hanger to tap from the stem end and out she came. I thought that the metered orifice on the rear brake side was pressed in but it was the shuttle. Major A-ha moment. The inside is pretty clean with no chunks just a tiny bit of sludge. This was my major concern. I could get some new O ring, and probably will, but they look pretty good and are tight.
Like Crap Game said in Kelley's Heroes, "You get a cookie."
Thanks Greg and everyone
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
[Re: cudaman1969]
#1344744
12/06/12 05:11 AM
12/06/12 05:11 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Actually most cars from the early 70's and up call them a combination valve many times as it has the dual funtion switch to move over and turn the brake lite on if you loose one side of the system but they also have the prop valve and a metering valve in that valve. The metering valve is only with disc brakes. Ron
[Re: Runnin74]
#1344747
12/06/12 06:18 PM
12/06/12 06:18 PM
Posts: 1,487 STL
cdstl
STL
I didn't replace anything. Everything looked good so I decided to put it back together and not end up with some wrong sized O rings that would bind.
Will let you know....
