Re: Best small block headers???
[Re: mopowers]
#1342971
11/29/12 06:52 PM
11/29/12 06:52 PM
Posts: 1,012 indiana
mcmopars
indiana
Are there any other good options out there that wont cost me $750?
no
[Re: mcmopars]
#1342972
11/29/12 06:53 PM
11/29/12 06:53 PM
mcmopars
indiana
no
well 650
[Re: RobX4406]
#1342974
11/29/12 07:01 PM
11/29/12 07:01 PM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
Summit/Jegs sells Dougs.
Amazon has them too with free shipping for about $595
Performance difference at 300-350hp... not worth a thought.
$600 w/ free shipping sounds like a good deal to me! Wish the TTIs were a little cheaper, but oh well. Dougs will do.
[Re: RobX4406]
#1342976
11/30/12 03:34 AM
11/30/12 03:34 AM
mopowers
Sac, CA
I like tti headers... except the price.
The worshipers have been in with nothing else fits lines. That's not correct, but, you can't get everyone to see.
I've run both and I've always bought Dougs unless there is something specific I'm looking for.
When you get in the 450hp range the tti will perform slightly better, maybe 8-10hp at peak. Not enough for me unless you are trying to run a number. At 300-400 range, you won't likely see a 4-5hp difference.
As long as the car isn't a 4 speed, you'll have little or no issues with either choice. Dougs even fit with a 727, which the catalog says they won't... go figure...
Might be better to go through summit. I don't believe they are hitting people with tax, unlike amazon. Summit has a free ship deal on right now.
Thanks Rob. I appreciate it!
[Re: mopowers]
#1342977
11/30/12 03:45 AM
11/30/12 03:45 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
TTI's mine look new after 10 years and 12K
[Re: MuuMuu101]
#1342981
11/30/12 12:43 PM
11/30/12 12:43 PM
Posts: 2,757 Gilbertsville, PA 19525
Pntastar69
And what issues may there be within the installation if one were to have a manual trans?
The lower arm of the z-bar may interfere w/the tubes. A little bending of the lower portion of the arm may be required to clear the tubes. I believe there is a specific z-bar available for that clearance. Again, just bent mine a tad, no problems at all. Other than that, excellent fit, no dinging the tubes but I have manual steering.
Others may have had to shim the motor mounts a tad for proper clearance. Maybe others will chime in on issues w/install.
