Best small block headers??? #1342962
11/29/12 01:51 PM
11/29/12 01:51 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
What are the best headers for a 340 A-body? Mild engine 300-400hp???
I've had headmans in the past, but they hang down extremely low. I would like something that tucks up a little tighter than those.
Re: Best small block headers??? [Re: mopowers] #1342963
11/29/12 02:01 PM
11/29/12 02:01 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
3 letters
TTI
Re: Best small block headers??? [Re: Pntastar69] #1342964
11/29/12 02:12 PM
11/29/12 02:12 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
3 letters
TTI
Cant go wrong there.
Re: Best small block headers??? [Re: 69B3GT] #1342965
11/29/12 02:36 PM
11/29/12 02:36 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Are there any other good options out there that wont cost me $750?
Re: Best small block headers??? [Re: mopowers] #1342966
11/29/12 05:07 PM
11/29/12 05:07 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Long tubes that fit, only two options.
Dougs D453 and tti.
Dougs are around 500-600 with ceramic coatings.
Re: Best small block headers??? [Re: RobX4406] #1342967
11/29/12 05:13 PM
11/29/12 05:13 PM
the house on the left.
cogen80 Offline
cogen80  Offline
Dougs D453 and tti.
Re: Best small block headers??? [Re: cogen80] #1342968
11/29/12 05:48 PM
11/29/12 05:48 PM
Eau Claire, WI
Charger727 Offline
Charger727  Offline
Eau Claire, WI
Yep - TTi
Re: Best small block headers??? [Re: RobX4406] #1342969
11/29/12 06:09 PM
11/29/12 06:09 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Where's the best place to get dougs?? and how do they perform vs TTIs?
Re: Best small block headers??? [Re: mopowers] #1342970
11/29/12 06:34 PM
11/29/12 06:34 PM
RobX4406 Offline
RobX4406  Offline
Summit/Jegs sells Dougs.
Amazon has them too with free shipping for about $595
Performance difference at 300-350hp... not worth a thought.
Re: Best small block headers??? [Re: mopowers] #1342971
11/29/12 06:52 PM
11/29/12 06:52 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
no
Re: Best small block headers??? [Re: mcmopars] #1342972
11/29/12 06:53 PM
11/29/12 06:53 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
no
well 650
Re: Best small block headers??? [Re: mopowers] #1342973
11/29/12 06:54 PM
11/29/12 06:54 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
they are not cheap,but they will be the last header you buy
Re: Best small block headers??? [Re: RobX4406] #1342974
11/29/12 07:01 PM
11/29/12 07:01 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
$600 w/ free shipping sounds like a good deal to me! Wish the TTIs were a little cheaper, but oh well. Dougs will do.
Re: Best small block headers??? [Re: mopowers] #1342975
11/29/12 07:13 PM
11/29/12 07:13 PM
RobX4406 Offline
RobX4406  Offline
I like tti headers... except the price.
The worshipers have been in with nothing else fits lines. That's not correct, but, you can't get everyone to see.
I've run both and I've always bought Dougs unless there is something specific I'm looking for.
When you get in the 450hp range the tti will perform slightly better, maybe 8-10hp at peak. Not enough for me unless you are trying to run a number. At 300-400 range, you won't likely see a 4-5hp difference.
As long as the car isn't a 4 speed, you'll have little or no issues with either choice. Dougs even fit with a 727, which the catalog says they won't... go figure...
Might be better to go through summit. I don't believe they are hitting people with tax, unlike amazon. Summit has a free ship deal on right now.
Re: Best small block headers??? [Re: RobX4406] #1342976
11/30/12 03:34 AM
11/30/12 03:34 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks Rob. I appreciate it!
Re: Best small block headers??? [Re: mopowers] #1342977
11/30/12 03:45 AM
11/30/12 03:45 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
TTI's mine look new after 10 years and 12K
Re: Best small block headers??? [Re: mopowers] #1342978
11/30/12 03:48 AM
11/30/12 03:48 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Can I add a couple questions to the thread? Do both Doug's and TTI allow for PS in A-Bodies? And what issues may there be within the installation if one were to have a manual trans?
Re: Best small block headers??? [Re: MuuMuu101] #1342979
11/30/12 09:47 AM
11/30/12 09:47 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
67 Barracuda - 410 with w2 heads and PS. TTI's fit but it is tight No denting needed! The point is TTI W2 headers are 1 7/8" primary
Re: Best small block headers??? [Re: MuuMuu101] #1342980
11/30/12 10:12 AM
11/30/12 10:12 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
If you check out their website they have all the footnotes and issues with fit listed.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Best small block headers??? [Re: MuuMuu101] #1342981
11/30/12 12:43 PM
11/30/12 12:43 PM
P
Pntastar69 Offline
Pntastar69  Offline
P
The lower arm of the z-bar may interfere w/the tubes. A little bending of the lower portion of the arm may be required to clear the tubes. I believe there is a specific z-bar available for that clearance. Again, just bent mine a tad, no problems at all. Other than that, excellent fit, no dinging the tubes but I have manual steering.
Others may have had to shim the motor mounts a tad for proper clearance. Maybe others will chime in on issues w/install.
