Re: Header Coating
[Re: PS Arrow]
#1342531
11/28/12 10:44 PM
11/28/12 10:44 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Looking for recomendations on getting headers coated. Preferably on the East Coast. I have used a place here in Tampa that did a good job, but they dont do the brite silver which was fine on the Arrow, but the new project is an open engine and I'l really like a nice job. Do most quality coating jobs do the inside also? Dont want to chrome,just a good ceramic job.
Thanks in advance, John
Give my friend Tommy (ex pro-stock bike racer) in FT Myers a call....he does awesome work 239-850-1669
Rickster
Re: Header Coating
[Re: MR_P_BODY]
#1342532
11/29/12 02:59 AM
11/29/12 02:59 AM
Posts: 26 Detroit, MI
CCPcoatings.com
Detroit, MI
Yes they do http://www.qccoatings.com/wherewereat.php
Hate to rain on your parade, but QC has never coated the inside of headers nor do most other shops. If you ask the right questions you'll get the right answer. Bill will tell you that they only spray inside the collector and primary area as far as you can see.
This is NOT ID coating. Even if it were done throughout with Bright Ceramic, in most situations Bright Ceramic would not stick to the inner primaries because it can't be prepped sufficiently. ID coatings are done with a different thermal barrier that is capable of bonding to less than ideal part prep.
CCPcoatings.com
Are you saying it doesnt bite to new tubing.. all the headers I have done are new tubing
Not at all, it doesn't have anything to do with new or used tubing. Bright Ceramic is VERY sensitive to preparation and coating thickness. In order to get Bright Cerm to bond properly the substrate has to be profiled in a very specific way which is rarely possible past your first bend. If it isn't the Ceramic will either flake off in the polishing process or blow out with the exhaust. Further, if the material is put on too thick, like someone flow coating it, it will again just flake off. Like I said, the bright shiny you see in your collector and head flange ends just past your line of sight. Jet Hot blew smoke up people butt with this BS for years.
